Old 07-13-2012, 12:47 AM   #1
sparkin88
Drives: 2010 Yaris 3D LB 5SD
Micro Image Lowering Springs Question
Just bought them but can't find anywhere about whether I need to cut the bump stops or not. Maybe I just suck with the search feature.
Garm? or Anyone that has them cut them or not? Can't wait to get them installed.
sparkin88 is offline   Reply With Quote
Old 07-13-2012, 08:55 PM   #2
new-yaris-owner
Drives: Toyota Yaris LE HB 2008
Then why don't you go see someone that can install them.. like a garage or something, someone who know how to install them will know what to do with it.
Get some pics when done ;)
new-yaris-owner is offline   Reply With Quote
Old 07-13-2012, 09:48 PM   #3
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
^ tbh I would venture to say a lot of shops would not cut them and let you bottom out simply because its not always necessary so they may not know better
OP: yes cut them about in half along the urethane sleeve portion its super easy to cut them and it will prevent you from bottoming out. GL and enjoy.
Old 07-13-2012, 09:52 PM   #4
sorry, just saw this. The Tanabe DF210 instructions suggest cutting the bump stops in half. I think that is a fair amount for our springs as well. Pretty sure I have a PDF of spring install on our forums under the Downloads section.
Old 07-15-2012, 12:47 PM   #5
cut 'em
Old 07-15-2012, 08:08 PM   #6
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
I didnt cut mine...i may do so when i upgrade the dampers
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 07-15-2012, 08:43 PM   #7
SAV912
Pirate Yaaaaris
SAV912's Avatar
I'm on the TRD suspension and I didn't cut mine. It specifically said NOT to. If you plan on upgrading your shocks any time down the line to match the springs, you shouldn't cut them.
Then again, even when I was on just TRD springs and stock shocks, I didn't cut mine and never bottomed out. Really, if you want that extra quarter inch or so, I suppose you could cut them.
-C
Georgia Bulldogs!
'09 Yaris LB 5MT Sold.
Old 12-22-2013, 02:23 PM   #8
CharlieBravo
CharlieBravo's Avatar
Drives: 2007 Yaris HB
Question on the MI springs: Is the writing, "Micro Image" supposed to be upside down when installed? I currently have one on right-side up, but it doesn't look right.
CharlieBravo is offline   Reply With Quote
Old 12-22-2013, 02:27 PM   #9
CharlieBravo
I'm talking about the front struts btw. But an answer on both the fronts and rears would be appreciated!!
Old 12-22-2013, 09:17 PM   #10
1.5
Form>Function
1.5's Avatar
I've always know the writing to indicate what direction the springs go. So if your writing is upside down then the spring would be up side down.
Old 12-23-2013, 12:24 AM   #11
yeah pretty sure the writing goes up.
Old 12-23-2013, 02:24 PM   #12
IllusionX
Drives: 07 Yaris Sedan Aero
They look right once installed..
Old 12-23-2013, 03:49 PM   #13
CharlieBravo
so here's OEM vs MI (with writing correct-side up). It looks like the top of the OEM better matches the bottom of the MI. I tried putting the MI spring in right-side up, but the "hat" would be be angled against the nut.
Old 12-23-2013, 03:55 PM   #14
CharlieBravo
Here's how I installed it (writing upside-down). It looks just like the OEM one. I've driven about ~15 miles on them so far,and everything seems ok. Been smooth road though. Tomorrow will be a little more bumpier as I head to work...
Old 12-30-2013, 05:05 PM   #15
That is incorrect. Writing goes right side up.
Old 12-23-2013, 04:42 PM   #16
1.5
Form>Function
1.5's Avatar
the "top" and "bottom" in the first pic dont look different to me on the MI spring so i dont see the difference that caused you to want to flip it
Old 12-23-2013, 10:58 PM   #17
CharlieBravo
Oh well......thanks for all the replies! I guess I'll re-attack it when I get new shocks/struts sometime down the road.....
Old 12-28-2013, 11:23 PM   #18
IllusionX
i believe my oem springs came out angled against the nut when i took it out..
what to look out for when installing lowering springs songa Performance Modifications 34 09-15-2012 03:29 AM
Micro Image lowering springs cali yaris Micro Image 20 09-03-2010 04:19 PM
WTB: Progress Lowering Springs Pitt Yaris Willing to Buy by private party 6 08-29-2010 02:17 PM
Lowering Springs - Questions ~ AGAIN ~ jaspie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 01-16-2007 12:23 AM
Lowering Springs - Questions ~ jaspie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 01-10-2007 08:21 AM
