![]() ![]() Drives: 2010 Yaris 3D LB 5SD Join Date: Aug 2011
Micro Image Lowering Springs Question
Just bought them but can't find anywhere about whether I need to cut the bump stops or not. Maybe I just suck with the search feature.
Garm? or Anyone that has them cut them or not? Can't wait to get them installed. |
![]() ![]() Drives: Toyota Yaris LE HB 2008 Join Date: Apr 2012
Then why don't you go see someone that can install them.. like a garage or something, someone who know how to install them will know what to do with it.
Get some pics when done ;) |
Form>Function
^ tbh I would venture to say a lot of shops would not cut them and let you bottom out simply because its not always necessary so they may not know better
OP: yes cut them about in half along the urethane sleeve portion its super easy to cut them and it will prevent you from bottoming out. GL and enjoy. |
sorry, just saw this. The Tanabe DF210 instructions suggest cutting the bump stops in half. I think that is a fair amount for our springs as well. Pretty sure I have a PDF of spring install on our forums under the Downloads section.
cut 'em
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
I didnt cut mine...i may do so when i upgrade the dampers
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
Pirate Yaaaaris
Drives: '00 Toyota Celica GTS 6MT Join Date: Aug 2009
I'm on the TRD suspension and I didn't cut mine. It specifically said NOT to. If you plan on upgrading your shocks any time down the line to match the springs, you shouldn't cut them.
Then again, even when I was on just TRD springs and stock shocks, I didn't cut mine and never bottomed out. Really, if you want that extra quarter inch or so, I suppose you could cut them. -C
Georgia Bulldogs! ![]() '09 Yaris LB 5MT Sold. |
![]() Drives: 2007 Yaris HB Join Date: Dec 2011
Question on the MI springs: Is the writing, "Micro Image" supposed to be upside down when installed? I currently have one on right-side up, but it doesn't look right.
I'm talking about the front struts btw. But an answer on both the fronts and rears would be appreciated!!
Form>Function
I've always know the writing to indicate what direction the springs go. So if your writing is upside down then the spring would be up side down.
yeah pretty sure the writing goes up.
so here's OEM vs MI (with writing correct-side up). It looks like the top of the OEM better matches the bottom of the MI. I tried putting the MI spring in right-side up, but the "hat" would be be angled against the nut.
Here's how I installed it (writing upside-down). It looks just like the OEM one. I've driven about ~15 miles on them so far,and everything seems ok. Been smooth road though. Tomorrow will be a little more bumpier as I head to work...
Form>Function
the "top" and "bottom" in the first pic dont look different to me on the MI spring so i dont see the difference that caused you to want to flip it
Oh well......thanks for all the replies! I guess I'll re-attack it when I get new shocks/struts sometime down the road.....
i believe my oem springs came out angled against the nut when i took it out..
2ZR swap. DO IT! Ask how!
Strange: one of my MI springs made the top bearing sit flat, the other was angled. I figured it would just level out after a while, but when I took them off this fall, the angled one was still angled and looked like it may have damaged the bearing. I was also experiencing very uneven tire wear on that spring. Perhaps there's a manufacturing defect? I'll see about getting pictures soon.
| what to look out for when installing lowering springs | songa | Performance Modifications | 34 | 09-15-2012 03:29 AM |
| Micro Image lowering springs | cali yaris | Micro Image | 20 | 09-03-2010 04:19 PM |
| WTB: Progress Lowering Springs | Pitt Yaris | Willing to Buy by private party | 6 | 08-29-2010 02:17 PM |
| Lowering Springs - Questions ~ AGAIN ~ | jaspie | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 01-16-2007 12:23 AM |
| Lowering Springs - Questions ~ | jaspie | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 16 | 01-10-2007 08:21 AM |
