Old 07-25-2012, 07:01 PM   #1
MadMax
MadMax's Avatar
Anyone Remove the Passenger Wiper?
I know it isn't the biggest "performance mod," but would improve the aerodynamics if only slightly!
I have been contemplating removing the small passenger wiper from my 08 liftback.
First, I hate how it stops almost in my line of sight and leaves a smudge there.
Secondly, I don't really see it being much of a benefit except for a passenger.
So I was wondering if anyone's tried it, and if so, how was it?
Cheers! M2
Old 07-25-2012, 08:05 PM   #2
Jason@SportsCar
Works fine. http://www.youtube.com/watch?v=gm4NJaZ3CHo
Old 07-25-2012, 08:27 PM   #3
Profotoiam
Drives: yaris
right know im running wiper free [no wipers at all] only problems ive had is when it rains.............
Profotoiam is offline   Reply With Quote
Old 07-25-2012, 09:30 PM   #4
MadMax
MadMax's Avatar
Good one!
Old 07-25-2012, 10:27 PM   #5
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
I was thinking you could get wing nuts (with lock washers) and just keep them in the trunk. pop them on if it rains. you wouldn't get the weight advantage (not really that much weight) but you would get the aerodynamic advantage (not really that much of that either).
it was an idea.
Old 07-26-2012, 06:49 AM   #6
bronsin
bronsin's Avatar
That would be ZERO benefit. And you might get a ticket or get sued in an accident.
Old 07-26-2012, 08:18 AM   #7
MadMax
MadMax's Avatar
Are you addressing removing both of them, or just one? As according to Texas law, all that is required is a "device" that clears moisture from the windshield...
§ 547.603. WINDSHIELD WIPERS REQUIRED. A motor vehicle shall be equipped with a device that is operated or controlled by the operator of the vehicle and that cleans moisture from the windshield. The device shall be maintained in good working condition.
Acts 1995, 74th Leg., ch. 165, § 1, eff. Sept. 1, 1995.
As long as one blade still remains and clears the windshield for the driver, there's no way you can be legally cited for it.
Plus, there are so many other obvious infractions of our vehicle code that a missing passenger wiper arm is not likely to catch an officer's attention even in an accident.
Believe it or not, it is legal to drive without a windshield in this state; as long as you have eye protection. I have dropped the windshield on my Jeep before, it's OK for toodling around the neighborhood or on a ranch but there's no way I'd drive on major roads like that!
Cheers! M2
Old 07-26-2012, 08:17 AM   #8
BEEF
BEEF's Avatar
why would you get a ticket or get sued? I could see if you were running without them when it was raining.
though there is usually a low pressure zone at the cowl on most cars, I would assume that the low pressure zone on the yaris is much smaller given the short hood and the slope of the front. that would mean that the advantage of lessening the drag at that point would be greater than on other cars. admittidly it is a small advantage but it is still an advantage. everything makes a difference. nothing makes ZERO difference. sometimes it's good sometimes it's bad.
fluid dynamics is an awesome field.
Old 07-26-2012, 07:12 PM   #9
Yaristeve
Drives: 3-door hatch
Actually, the base of the windshield is a high pressure zone. Thus, the cowl induction hood scoops.
To OP: if ultimate aerodynamics is your goal, not only can you remove the passenger side wiper, but how about resetting the actuator arm to make the driver side "rest" in the up position along the A-pillar...
Old 07-26-2012, 07:32 PM   #10
BEEF
BEEF's Avatar
I stand corrected.
Old 07-26-2012, 10:56 PM   #11
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
I did this for years until the GF complained about it
The mod is so simple, just unbolt the idler arms from the motor and turn 180, then re attach.
Old 07-26-2012, 11:20 AM   #12
Mine are off. It never rains here. The only water I see is on my neighbor's lawn every morning and in bottles at the store.
Old 07-26-2012, 11:23 AM   #13
From CA DMV.
We may actually have to run two wipers per the Federal standard (which I am not looking up )
Windshield Wipers
26706. (a) Every motor vehicle, except motorcycles, equipped with a windshield shall also be equipped with a self-operating windshield wiper.
(b) Every new motor vehicle first registered after December 31, 1949, except motorcycles, shall be equipped with two such windshield wipers, one mounted on the right half and one on the left half of the windshield, except that any motor vehicle may be equipped with a single wiper so long as it meets the wiped area requirements in Federal Motor Vehicle Safety Standards Governing Windshield Wiping and Washing Systems.
Old 07-29-2012, 07:43 PM   #14
Scubaru Steve
Awesome!
Drives: 12 Yaris/07 yaris
mine works fine with no pass wiper
Yaris wiper video
i wonder if this could be a swap to older models. refills are cheap at $12
Old 07-29-2012, 08:21 PM   #15
MadMax
MadMax's Avatar
Yaris wiper video
OK, you've got my attention! Details on this mod, please...
Old 07-29-2012, 08:51 PM   #16
Bluevitz-rs
^^It's called a 2012 Yaris.
Old 07-29-2012, 09:06 PM   #17
MadMax
MadMax's Avatar
Wow, I never noticed that on the new model...
It would be interesting to see if it would retrofit.
Cheers! M2
Old 07-29-2012, 09:10 PM   #18
Bluevitz-rs
not a chance LOL. Unless you're thinking of replacing the entire front cowl
Permanently remove passenger seat? tendomentis DIY / Maintenance / Service 12 12-01-2017 02:16 PM
Passenger side windshield wiper daf62757 General Yaris / Vitz Discussion 1 12-23-2011 05:12 PM
Passenger Wiper Arm, lack of tension? TSB? Lil Abner DIY / Maintenance / Service 8 10-24-2010 01:37 PM
