Old 03-11-2007, 01:16 PM   #1
Yarisagos
Drives: Yaris
Offsets?
I am ready to order my wheels and tires.
Getting the 17" SportMax 001 and 205/40/17 FALKEN ZIEX 512.
I know what an offset is, but how do i know what i am getting?
Or better yet, what I need?
Do I just tell the wheel place, whats my car and what rims, tires i want. Then they firgure out if its going to work?
Thank you for the help.
Yarisagos is offline   Reply With Quote
Old 03-11-2007, 01:19 PM   #2
Black Yaris
der Zeck
Black Yaris's Avatar
please just do a search before asking questions...
I am sure you are going with a 7 inch wide wheel, so it will be a +38 offset
and BTW the correct size tire is 215/40R17, and I would think twice about those tires, they only tend to last about a year under normal driving
Old 03-11-2007, 01:35 PM   #3
Yarisagos
Drives: Yaris
Thank you for a fast answer.
I did do a search, but i wanted a direct answer to my question, not chancing 800 bucks over the net for the wrong wheels.
I am still confuse with your answer, you said the offset would be +38, but this site shows 4x100, 7 inch to be +40.
http://www.edgeracing.com/wheels/sportmax/
Your saying i need to order a 7 inch with a +38 offset?
http://www.edgeracing.com/tires/2054017/
Those tires are rated 360 tread wear?
I thought anything above 350 is good for longevity? Unless the manufacture lies about the spec, i wouldn't doubt it, he he.
Thank you again.
Old 03-11-2007, 04:24 PM   #4
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
You'll be fine with a 40mm offset. With a 7 inch wide wheel anything between 38mm and 45mm will work. Also, I have that same size tire and it works great. You may want to listen to blackyaris about the treadwear on those Falken's however.
Old 03-11-2007, 05:22 PM   #5
Nutzoids
Nutzoids's Avatar
Drives: 07 Yaris Liftback
I beg you to re-consider… Sport Maxx Is a very good looking Wheel… Cheap too, but those wheels are so fucking heavy…
You will not be happy when you find out that your new good looking Rims are actually slowing down your car!
Weight is a very important factor in buying wheels for this car… Light weight… Trust me!
Nutzoids is offline   Reply With Quote
Old 03-11-2007, 05:29 PM   #6
Yarisagos
Drives: Yaris
Its 5.1 pounds more then the stock ones.
I could get the 16" and drop it to 2lbs over the stock weight?
Does is really matter at those weights?
Old 03-11-2007, 05:26 PM   #7
Yarisagos
Drives: Yaris
Thank you, thats what i needed to know.
Whats a good tire to get?
Old 03-11-2007, 06:24 PM   #8
PetersRedYaris
Tire choice is personal preference. I don't know anything about the choices edge racing has to offer but you can look up tire reviews. Those wheels are not to heavy for your car. My tire/wheel package weighs about the same as yours will and I can hardly tell the difference. If you like those wheels, by all means, indulge yourself.
Old 03-12-2007, 08:06 AM   #9
Black Yaris
der Zeck
Thank you again.
UTQG is set by the manifacture, so a 360 with Bridgestone could be good, but with Yokohama be shitty.... so you realy can't go by those, mileage ratings are about the only thing some what consistant.... The only reason I know about those exact tires is that I used to sell them and had nothing but complaints because of premature tire wear, and poor traction in the rain and very poor in the snow
Old 03-11-2007, 05:56 PM   #10
jdubau55
Drives: 2007 White Yaris LB 5 Spd.
Send a message via AIM to jdubau55 Send a message via Yahoo to jdubau55
Have you looked at the wheels our vendors in the Sponser Classified section are offering??? Very good prices on some decently light weight wheels.
jdubau55 is offline   Reply With Quote
Old 03-11-2007, 06:08 PM   #11
Yarisagos
Drives: Yaris
Yep, take a took at these pics, and you see why i want it.
Its a Scion, but a Yaris would make it look even better.
Also my Yaris is the same color as the Scion.
http://www.sportmaxwheel.com/gallery...el=album&id=38
Old 03-11-2007, 10:28 PM   #12
jdubau55
I had them. They were pretty good. Esp for the price. They lasted me about 25-30k miles but I didnt really rotate and check the pressure like I should.
Old 03-11-2007, 10:38 PM   #13
Yarisagos
Drives: Yaris
Yep, you can not beat a price of $ 788 shipped for both Rims and tires.
Ready to be install.
I did the math, the pressure needs to be at 36.36 psi.
Wheel Offsets bigsky2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 03-08-2007 01:55 AM
