You'll be fine with a 40mm offset. With a 7 inch wide wheel anything between 38mm and 45mm will work. Also, I have that same size tire and it works great. You may want to listen to blackyaris about the treadwear on those Falken's however.
| Wheel Offsets | bigsky2 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 03-08-2007 01:55 AM |
