Old 03-12-2007, 12:15 PM   #1
luckydlb
Drives: 3dr Black Yaris Liftback
I know its been asked before..but i still don't know
I apoligize for asking, because i know its been answered, but I still don't understand how to take of the window crank to access the front speakers in my liftback. pictures would be extremely helpful, or a step by step, just make sure a not smart person could understand it.
Thanks in advance.
luckydlb is offline   Reply With Quote
Old 03-12-2007, 01:38 PM   #2
ChinoCharles
Drives: LB
You need to wedge something between the handle and that white/opaque spacer. I used a zip tie last night and it worked fine. Just work a zip tie in there and twist it around, putting pressure on the center of the crank. Eventually you'll pop the little retention clip out enough to take it out and get the handle off.
It'll take a while to get it the first time, but once you do it once it'll make more sense.
Old 03-12-2007, 01:48 PM   #3
luckydlb
thanks for your help...when i read other posts i thought u had to somehow get into the door pannel and work a rag around back there...and was a bit confused....lol..
thanks again
Old 03-12-2007, 04:24 PM   #4
jdubau55
Drives: 2007 White Yaris LB 5 Spd.
Send a message via AIM to jdubau55 Send a message via Yahoo to jdubau55
Heres a lil drawing. You put the rag between the handle and the door panel. This will catch that clip and push it off.
jdubau55 is offline   Reply With Quote
Old 03-12-2007, 04:35 PM   #5
ChinoCharles
Drives: LB
Good job! You get three gold stars today! That drawing is TIGHT! Actually, its damn accurate too.
Old 03-12-2007, 07:00 PM   #6
MrJester
Drives: homo
Honestly I could not get the rag trick to work best bet is buying the stupid tool for $7-$9
MrJester is offline   Reply With Quote
Old 03-12-2007, 09:35 PM   #7
jdubau55
You kinda have to try to look hard behind the handle to see where the ends of the clip are then put your rag on the ends so it will push it off. If you just shove the rag behind there and go for it you might be pushing in on. Once you figure it out its a breeze.
Old 03-12-2007, 09:08 PM   #8
KSIbucky
KSIbucky's Avatar
Drives: 2007 Yaris manual dark silver
Send a message via AIM to KSIbucky Send a message via MSN to KSIbucky
how does the clip keep it on there
7 Color Tach
Fujita Intake
Momo pedals Shift knob and boot. Full TRD SSK.
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
KSIbucky is offline   Reply With Quote
Old 03-12-2007, 09:33 PM   #9
jdubau55
Side profile view...Clip goes around part of the crank handle something like that to keep it from easily pulling off. Thats why you must remove the clip. Othewise, you pull the whole door panel and window regulator all out.
Im a paint master....
Old 03-12-2007, 09:59 PM   #10
TrancosRt
TrancosRt's Avatar
Drives: 07 Silver HB Yaris
The clip ends are facing the crank, so slipping the rag between the crank and the door panel grabs the ends. Then wrap the crank axis, and pull the rag back and forth until it pops out. (mind you, when it does pop up, IT REALLY does... I had to chase it!)
TrancosRt is offline   Reply With Quote
Old 03-12-2007, 11:51 PM   #11
ChinoCharles
Drives: LB
Yeah, don't lose that sucker.
You guys should see the inside of my car right now. The paneling is in the trunk.
Old 03-13-2007, 12:04 AM   #12
Black Yaris
der Zeck
Black Yaris's Avatar
I think I figured out the problem on your drivers window...
The wiring was all wrong
Old 03-13-2007, 12:18 AM   #13
ChinoCharles
Drives: LB
Haha, oh I had the wiring right. Somewhere between me testing it and getting the driver's side door panel back on I must have jarred a connection loose somewhere. It'll be fun following wire around my car later. Ohhhh yeah baby, real fun.
Old 04-28-2007, 11:23 AM   #14
JustYYaris
Drives: 2007 Blazing Blue Hatch M/T
I'm not sure if this has been clearly pointed out, but the rag goes between the plastic spacer and the actual crank. After 15 minutes trying between the door and the spacer, it came to me that maybe they meant between the crank/spacer! Could just be I wasn't reading directions or wasn't getting it, but good to know! I'm in my car doing it right now, rag trick works awesome!
PS: How does it go back on? lol
JustYYaris is offline   Reply With Quote
Old 04-28-2007, 01:13 PM   #15
spkrman
Drives: 1
easiest is to use the tool, even a monkey could use it and pop off the crank in 30 seconds... that includes chuggin a beer.
on that note, I noobed it up and the clip flew into oblivion... the replcaement clips @ advance dont fit properly, sux.
Old 12-09-2012, 03:05 PM   #16
MarkCamp
Drives: 2007 Yaris Hatchback
It took me about 2 seconds once I figured it out! Use a screw driver to lift the handle away from the white washer. Place the rag so the edge starts in the handle area. Pull the rag around the shaft, away from the handle. The end of the clip, which is pointed towards the handle end, will get caught and the clip will just pop out!
MarkCamp is offline   Reply With Quote
Anyone have Yaris air and oil filter numbers? Yaris_Fan DIY / Maintenance / Service 54 02-11-2009 01:14 AM
sum dude asked if my car was electric... Blenjar General Yaris / Vitz Discussion 17 01-12-2007 10:39 PM
How often do you get asked "is that a Yaris?" Jfoofoo General Yaris / Vitz Discussion 23 12-14-2006 11:11 PM
This is my buying experience yoyoche New YARIS Purchase Forum 9 08-13-2006 08:01 PM
How much do you think they make? Chaad32 New YARIS Purchase Forum 38 08-05-2006 08:50 AM
