Old 12-19-2012, 10:28 PM   #1
b_hickman11
Drives: 08 Sedan
A/c & heater fan not working
The fan has been working off and on for the past few weeks. I have checked all fuses and they are all good. Tonight it would not blow for about 20 minutes and then all of a sudden it started working again. Once it comes back on it operates normally. I have also pulled the cabin air filter out and visually inspected the fan blades to make sure nothing was nothing stuck in the unit. Any suggestions?
Old 12-19-2012, 10:47 PM   #2
It could be the motor going bad or the HTR relay, which is located within the bowels of the body ECU.
When it is not working try carefully spinning the fan to see if it then continues to run.
Old 12-20-2012, 05:36 PM   #3
b_hickman11
Drives: 08 Sedan
I tried manually spinning the fan with my hand to see if the motor was just getting stuck but that didn't do anything. When it is working it works at normal speed. When it's not working and I turn the knob from off to on, I can hear a "click" sound coming from underneath the steering wheel/fuse box area.
Old 12-20-2012, 06:36 PM   #4
The click is theoretically a good sign that the relay in the body ECU is alive.
Try running it just on the highest setting, which bypasses the blower resistor (which is responsible for lowering the speed and has an internal fuse).
Do you per chance have access to a multimeter?
Old 12-20-2012, 09:41 PM   #5
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Maybe the relay has bad contacts.
Old 12-20-2012, 09:44 PM   #6
Exactly. That's why I am asking if he has a meter to check the output.
Old 12-22-2012, 12:18 AM   #7
b_hickman11
Drives: 08 Sedan
Yes I have the meter. Where do I need to check?
Old 12-22-2012, 07:55 AM   #8
Pull the two pin connector off the bottom of the fan motor (above the passenger footwell) and measure the voltage between the two pins. Black is + and blue is -.
Ideally you want to measure it not working, as working it will obviously have power there. The question is if it has voltage on the black wire when the fan is not working.
If it does, then plug the connector back in and also measure the voltage on the blue wire with respect to a chassis ground (bolt into metal under the dash).
Old 12-22-2012, 12:31 AM   #9
Bluevitz-rs
I'd first check and see if you even have any voltage at the motor with the fan switch on
Old 12-22-2012, 12:38 AM   #10
b_hickman11
Drives: 08 Sedan
During one of the times the motor is working or during one of times it's messing up?
Old 12-22-2012, 06:05 AM   #11
BLH
Drives: 2007 Yaris Sedan
Both working and not working. Would allow you to compare them.
Not working would be the one to test if you didn't do both.
BLH is offline   Reply With Quote
Old 12-22-2012, 07:56 AM   #12
Bluevitz-rs
Well if the fan is spinning it's pretty obvious there's voltage there... If you turn it on and there no voltage at the fan you start tracing back being carful trying no to disturb the connectors. The worst thing to do trying to diagnose an intermittent problem is wiggle everything around because if there a bad connector it just makes it harder to find. But seeing how the fan circuit is fareley simple it's easy enough to check all connections.
Old 12-22-2012, 08:14 AM   #13
With a high current device like the fan, a connection issue is not likely the issue, as a poor connection with high current results in the generation of heat and melting of connectors.
Old 01-06-2014, 09:24 PM   #14
JEdlinger
Drives: 2008 Toyota Yaris
Same issue
I know this is an old thread, but it EXACTLY describes what is happening with my car. Did you figure it out?
JEdlinger is offline   Reply With Quote
Old 01-06-2014, 10:10 PM   #15
I never heard an update and the person with the issue has not been on here in over a year. I suggest trying the same tests as we described above.
Old 01-05-2016, 03:09 PM   #16
scoobopdan
Drives: 2008 Yaris
I'm having the same issue and plan on replacing the fan soon. I've seen some random links to good places to check, but the threads and links are old and outdated. CT, do you have a good online resource for something like that?
scoobopdan is offline   Reply With Quote
A/C or Heater Core leaking into passenger floor? The Shape DIY / Maintenance / Service 3 03-23-2015 12:40 AM
heater not working water coolant level drops Mike Hancock DIY / Maintenance / Service 4 11-03-2011 02:14 PM
Using the fan, heater signs Fuel Economy Forum 58 03-13-2009 01:31 PM
Rattling Noise with A/C Fan? Sabretooth DIY / Maintenance / Service 16 05-15-2007 03:27 AM
