Old 12-22-2012, 07:56 AM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Well if the fan is spinning it's pretty obvious there's voltage there... If you turn it on and there no voltage at the fan you start tracing back being carful trying no to disturb the connectors. The worst thing to do trying to diagnose an intermittent problem is wiggle everything around because if there a bad connector it just makes it harder to find. But seeing how the fan circuit is fareley simple it's easy enough to check all connections.
Old 12-22-2012, 08:14 AM   #2
With a high current device like the fan, a connection issue is not likely the issue, as a poor connection with high current results in the generation of heat and melting of connectors.
A/C or Heater Core leaking into passenger floor? The Shape DIY / Maintenance / Service 3 03-23-2015 12:40 AM
heater not working water coolant level drops Mike Hancock DIY / Maintenance / Service 4 11-03-2011 02:14 PM
Using the fan, heater signs Fuel Economy Forum 58 03-13-2009 01:31 PM
Rattling Noise with A/C Fan? Sabretooth DIY / Maintenance / Service 16 05-15-2007 03:27 AM
