Old 08-06-2013, 10:44 AM   #1
caper26
caper26's Avatar
Drives: 2010 4D Sedan 5M w/convenience
Check Engine Light on at 32k kilometers?
Just at the title says. check Engine Light came on with 32,500 kilometers on my 2010. That's right. Very low km's, with engine light on. I had the dealer switch the oil to the upgraded synthetic (blend?) from the very first oil change. I use Lucas gas treatment occasionally. Right now my only reliable car is my 81 Z-28... My 2000 Xterra is on its 3rd major visit to the mechanic in under a year as we speak. Of course I don't want to visit the dealership which is 1/2 hr away, and spend god-knows-how-much on computer scanners, etc... That stuff should be free while it is under warranty...
caper26 is offline   Reply With Quote
Old 08-06-2013, 10:47 AM   #2
You need to have someone read the code, as there are hundreds of reasons why it could come on (from as benign as loose gas cap). Most auto parts stores will read codes for no charge.
Old 10-11-2013, 10:00 AM   #3
caper26
caper26's Avatar
#1 and #4 cylinder misfire, and a corresponding 'random' misfire code.
wtf? Code is cleared for a couple days now, but I noticed my mileage went to pot about 9 months after I bought the car (which corresponded to fall/winter in Canada). Need to get an oil change soon so I will talk to the dealship and see what they say about it. Hate paying for detailed diagnostics when I have an extended warranty which should cover that sort of crap.
Old 10-11-2013, 12:09 PM   #4
Typically that is caused by spark plug or coil issues. My bet is fouled plugs from some bad gas.
Old 10-11-2013, 10:16 AM   #5
That's an American luxury. Very hard pressed in Canada to find someone who will not soak you for an easy $100 to plug in a code reader.
Old 10-11-2013, 02:47 PM   #6
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
just to let u know our pc with build in code reader and everything else possible that one can do to a toyota is $ 6k to buy we got 3 of them...anyone is welcome to buy a cheap just code reader at CT...that is once choice but as for free i dont agree...the place pays good money for the equipment i pay crazy money for my tools went to school also...so what makes u think it should be free ..warrant will cover lots ...but dont expect anyone to do anything free.
just my 2 cents on this ....at least we will get it right the first time not like ur average shop.
Old 10-11-2013, 03:17 PM   #7
barryware
In the US.. ALL the parts stores will read your codes for free.. They do this so you will buy the repair parts needed to correct the problem. Most other shops (Sears, Midas Muffler, etc.) will also read the codes for free in hopes you will let them fix the problem.
Most can only read the ECM.. Any of the other computers on the car (power steering, body, A/C, etc.) takes the techstream or some other sophisticated, expensive head tool which some shops have, and some do not.
My 2 cents..
barryware is offline   Reply With Quote
Old 10-11-2013, 04:05 PM   #8
^ This.
I can't tell you how many times a Canadian on this site has posted concerning check engine light, and they will almost always get a 'most auto parts (ie. AutoZone) will scan for free' response.
We don't have AutoZone here with the closest comparable being PartsSource and NAPA. Both these operations do not extend this service under the hope that you will buy your parts from them. The closest we do get is the periodic special run by some shops who will wave the diagnostic fee if you have them perform the necessary repairs. Otherwise, it is pay for the read + parts + labour.
I'm not dumping here, just pointing out that the free diagnostic from your local parts store is not an applicable response for us.
Old 10-14-2013, 01:57 PM   #9
caper26
caper26's Avatar
Scan should be free as a loyal customer who will get the repairs or parts at that shop.
When you get a brake job, do they charge you "diagnostic fees" of $30 to tell you that you need new brakes? No.
We pay mechanics to find the problem and fix it. Just because they want to use a computer at MY expense, doesn't sit right with me.
Old 10-15-2013, 02:34 PM   #10
dj92
Embracing Curves
dj92's Avatar
Drives: '14 Prius Executive
Often poorly done work (e.g. not checking a battery that was in fact dead and blaming it on the ECM) let me come to the decision to fix my cars on my own, including maintenance.
In the end, it saves me a lot.
I had changed the air filters in less than half a minute, changing oil and its filter were done in less than an hour.
~20€ or so for the 3 filters, 50 for a canister of oil that's still got about 2l in it, that's totally okay for me to spend that every second or third year.
Paying the workshop 100€ in addition (some rumors said even 200€) isn't at all.
I lose the rust warranty, but if it rusts too bad in about 10 years or so, the saved money will be by far enough to fix it
dj92 is offline   Reply With Quote
Old 10-11-2013, 12:03 PM   #11
barryware
car is still under warranty.. no?
Old 10-14-2013, 01:53 PM   #12
caper26
caper26's Avatar
Yes. Bought the extended warranty to 5 years
Old 10-14-2013, 02:20 PM   #13
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
if you got a smart phone you can get a code reader for under $25.. elm327 bluetooth or wifi.. works flawlessly...
Old 10-15-2013, 12:21 PM   #14
caper26
caper26's Avatar
I had the codes read with OBD II. It was misfire on 2 & 4, and random misfire codes. Wondering what I should do now.
Old 10-15-2013, 12:45 PM   #15
bairjo
I think CTScott already gave a suggestion
Old 10-15-2013, 01:29 PM   #16
Clear the codes. Swap the coils from 2 & 4 with 1 & 3. If the coils are bad, then the next cel should indicate misfire on 1 & 3. If it is still 2 & 4, then spark plugs are next to look at.
Old 10-16-2013, 12:27 PM   #17
caper26
caper26's Avatar
Thank you. This is really annoying with under 40K km's. I cleared the code last week, and will see if it returns.
I read somewhere there has to be a certain number of misfires before the CEL lights up?
Check Engine Light P0455, P0441, P0456 RedStickHam DIY / Maintenance / Service 8 12-01-2013 12:41 PM
help..check engine again dindy DIY / Maintenance / Service 12 12-13-2012 06:17 PM
MAF check engine light and transmission help heeroyuy01195 DIY / Maintenance / Service 22 04-03-2012 02:16 PM
Check Engine "Injector failure Code" YarisPR DIY / Maintenance / Service 14 03-04-2007 08:13 PM
