#19 |
I think CTScott already gave a suggestion
#20 |
Clear the codes. Swap the coils from 2 & 4 with 1 & 3. If the coils are bad, then the next cel should indicate misfire on 1 & 3. If it is still 2 & 4, then spark plugs are next to look at.
#21 | |
Embracing Curves
Drives: '14 Prius Executive Join Date: Aug 2013
In the end, it saves me a lot. I had changed the air filters in less than half a minute, changing oil and its filter were done in less than an hour. ~20€ or so for the 3 filters, 50 for a canister of oil that's still got about 2l in it, that's totally okay for me to spend that every second or third year. Paying the workshop 100€ in addition (some rumors said even 200€) isn't at all. I lose the rust warranty, but if it rusts too bad in about 10 years or so, the saved money will be by far enough to fix it
#22 | |
![]() ![]() Drives: 2010 4D Sedan 5M w/convenience Join Date: Apr 2011
I read somewhere there has to be a certain number of misfires before the CEL lights up? |
| Check Engine Light P0455, P0441, P0456 | RedStickHam | DIY / Maintenance / Service | 8 | 12-01-2013 12:41 PM |
| help..check engine again | dindy | DIY / Maintenance / Service | 12 | 12-13-2012 06:17 PM |
| MAF check engine light and transmission help | heeroyuy01195 | DIY / Maintenance / Service | 22 | 04-03-2012 02:16 PM |
| Check Engine "Injector failure Code" | YarisPR | DIY / Maintenance / Service | 14 | 03-04-2007 08:13 PM |
