Old 03-30-2007, 05:52 PM   #1
rwseattle
Rwseattle
rwseattle's Avatar
Drives: 2007 Toyota Yaris (BASE)
RPM problem.
My yaris runs great but, when it idles standing still the RPM is dancing slightly. You can feel the RPM going up and down in the seats. Its annoying. Anyone else have this problem. I think I will take it to the dealer this week for a computer reading.
rwseattle is offline   Reply With Quote
Old 03-30-2007, 06:49 PM   #2
turboyaris
Drives: 2007 Yaris Sedan
Send a message via AIM to turboyaris
it has to do with the whole drive by wire deal or so I was told. A small kink in the ETB I'd imagine. This is also not helped by the Yaris's lower then normal idle. Mine usually idles at about 4-500 rpms which is really low. I wouldn't say anything is wrong with your car, they may be able to adjust like an idle air valve or something along those line, but I have it to, and I'm not worried about it.
turboyaris is offline   Reply With Quote
Old 03-30-2007, 11:15 PM   #3
rwseattle
Rwseattle
rwseattle's Avatar
I understand. I will make a appointment with the local dealer and have them investigate the problem. I'm not worried about the idle but It would be nice if they improved the problem. I will post a tread next week.
Old 03-30-2007, 11:50 PM   #4
Black Yaris
der Zeck
Black Yaris's Avatar
do a search... every Yaris is doing it....
Old 03-31-2007, 01:00 AM   #5
tiksman
tiksman's Avatar
Drives: 07 Red Hatch
mine is bad when the ac or defrost is on
tiksman is offline   Reply With Quote
Old 03-31-2007, 07:57 AM   #6
Black Yaris
der Zeck
same here... from what I hear the NST crank pulley solves a lot of this problem... and when NST comes out with the full line of pulleys for our car I am sure she will run smooth as silk
Old 03-31-2007, 03:01 PM   #7
Spades
The Hated One
Spades's Avatar
Drives: 07 White Manual Sedan
yeah, my yaris does it too...runs nice and smooth untill every so often when it goes from a smooth idle at 700-800 rpm and then drops to 400 rpm...sounds like the car is dying and the whole car shudders...very annoying...I am hoping toyota does a recall on it...
Old 04-03-2007, 11:09 AM   #8
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
The VVTi just lowers the RPMs for economy and to pass the law restrictions as far as emissions are concerned.
Gas pedal problem? Befuddled Performance Modifications 28 01-27-2010 09:55 AM
Electronic Trunk Release Problem jonr0613 DIY / Maintenance / Service 5 09-08-2007 06:13 AM
HELP!! HID problem 07yaris_fe General Yaris / Vitz Discussion 2 11-20-2006 06:00 AM
Service Problem Lizardboy DIY / Maintenance / Service 19 10-06-2006 09:12 PM
Shifting RPM GabL DIY / Maintenance / Service 10 08-06-2006 05:40 AM
