![]() Drives: 2012 Toyota Yaris Join Date: Oct 2013
RPM question
Iv noticed while driving on the highway, my RPM's are around 3200-3500. Now my question is will driving at these high RPM's ware out the engine faster? Because other cars i drive are less than this. Thanks for the help.
That's about the correct rpm range for ~70 mph or so, and is typical of engines of this displacement.
Were your other cars 6 or 8 cylinders? An 8 cylinder can cruise along at the same speed while only spinning around 1600 rpm.
#3 | |
![]() ![]() ![]() Drives: '08 Yaris LB Join Date: Jan 2012
I found it pretty alarming at first too. |
I found it alarming as well, but i only had the car for 2 weeks or so. So i guess ill get used to it. Also will reving it more hurt the mpg? thanks again for all your help guys.
#5 | |
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
Greg |
LOL you are never going to be driving at 1200rpm@60mph :P
not like old GM cars.. my old swift with a 3 spd auto trans did 4000rpm@70mph. |
#8 | |
Remember that similar cars get the same mpg as the Yaris (or lower) and they all have 5-6 speed automatics too! The AT is definitely a bit higher than that. |
| IL: Chicago - Haunted RPM Car/Bike Show - October 20th, 2012 | RPM JEFF | Great Lakes | 0 | 09-24-2012 04:40 PM |
| IL: Chicago - Haunted RPM Car/Bike Show - October 20th, 2012 | RPM JEFF | Mid-Atlantic | 0 | 09-24-2012 03:10 PM |
| Vitz 2001 1.0 manual rpm | diesel2901 | DIY / Maintenance / Service | 4 | 09-23-2011 12:02 AM |
| Turbocharged Dyno Result | cdydjded | Forced Induction Forum | 24 | 08-23-2010 10:54 PM |
| Source code for Yaris Tachometer | metalshark | DIY / Maintenance / Service | 27 | 04-06-2009 12:41 AM |
