#1 |
![]() ![]() ![]() ![]() Drives: Yaris LB Turbo Join Date: Aug 2006
Turbocharged Dyno Result
Well today has been an interesting day. I posted an opinion earlier here & always a certain member which will remain nameless, critisize everything I stated. So I took this oportunity to dyno my car. I did this to see how much power I gained after I turbo'd my car & find out if what I was stating earlier was right or wrong. What I stated earlier was the following: you cant run TC injectors on a boosted Yaris without reprograming the ECU. What will happen is that you will run rich & have a high RPM misfire. I base this on 3 members who were boosted, were running TC injector & all suffered from high RPM misfires. Now I might be wrong & Ill be the first to admit it. So to prove my point I dyno my car and here are the results:
Run 1 Stock Injectors Boost 4-5lbs Max HP 151.77 Max TQ 133.49 AFR 3500 RPM 13.20 4000 RPM 13.00 4500 RPM 12.80 5000 RPM 12.80 5500 RPM 13.40 6000 RPM 13.20 6500 RPM 12.80 As you can see the car was running on the lean side. I knew & stated earlier that is was. I made 3 more runs and all the results were roughly the same. Runs 4-9 had the following results: Run 9 1ZZ Injector Boost 4-5lbs Max HP 154.40 Max TQ 137.05 AFR 3500 RPM 10.00 4000 RPM 10.00 4500 RPM 10.00 5000 RPM 10.40 5500 RPM 11.20 6000 RPM 11.60 6500 RPM 10.20 Now Im running rich. I was going to raise the boost to 6-7lbs but was not able to. What I will do now is drive the car for about a week to see if the factory computer compinsates for the larger injector. Then I will install the TC injectors. Stay tuned........ DSC01500.JPG DSC01499.JPG DSC01498.JPG DSC01497.JPG |
![]() ![]() ![]() ![]() ![]() Drives: Toyota Yaris Sedan 09 STD Join Date: May 2009
Nice Numbers!!
You got PM
#3 |
Bathroom + Laptop = <3
So whats wrong with running the 1ZZ injectors? 11.2-11.5 is kinda the money zone, thought you need to wait a cycle or too which is like 80 miles of driving before the ecu can start relearning itself. If you just slap injectors in the car, you are going to have the ecu keep the same constant of injector latency and it will just dump fuel. The O2 sensor is obviously going to see this and try to lean it out some more.over time.
I don't get why you people aregue over goofy crap, i read the other thread and you can't just internet hunt for information without having the knowledge to back it up. So just add some more airz and balances its outs to 10.8-11.8afr range kabloom kaplowie |
#4 |
I did not internet surf for my info. I know what Im talking about. But there is no way to prove it without results. I could not put into words what I was claiming. I found the MSD page to prove my point. And it was not the only page stating what I know is correct. Yes Im going to drive around & dyno again. Im going to remove fuel with the AEM FIC & get the AFR's in the 11.8-12.2 zone.
#5 |
the FIC is still a piggy back correct? If you have no way of feeding it the stock O2 sensor and having it put out an altered narrowband signal you will be at constant war with the ECU and you will just have to live with what it gives you? Because thats just how these systems work? right
#6 |
Yes the FIC is a piggyback. It only modifies signal under boost, it has a built in map sensor. We will soon find out if it works like I intend to use it.
#7 |
Props to you for doing MULTIPLE dynos, trying various combinations and testing out these parts in REAL LIFE. And why -- because you want to know, just like everyone else does. Who else is willing to do even that much.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
When I tried to run tC injectors, my AFR wideband completely pegged out on the rich side. With the smaller 1ZZ injectors, I am getting nearly the same AFR readings you have. Maybe a tiny bit higher.
I get around 7-8lbs boost from the Blitz S/C.
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
#9 |
There has been some comments about what is the correct AFR my car should or is running. Some people say it lean & some say it rich. This is what I will do to my car & those going to boost their cars can do the same or go in another direction. Im going to let the factory ECU control the AFR's while not in boost. Now while under boost/wide open throttle Im going to use the AEM FIC to get the AFR's in the 11.8:1-12.2:1 range. This is my opinion on how I want my car to run. Please if you feel I have no idea what Im doing keep you comments to yourself. I really dont want to here them. Im sorry if this sounds harsh but Iv had enough of this he said she said crap.
#10 |
![]() ![]() ![]() ![]() Drives: 2008 Black Sedan Join Date: Oct 2008
good luck m8
#11 |
#12 |
Form>Function
Drives: 07 Flint Sedan Join Date: Dec 2009
150+ nice numbers
#13 |
C'est la vie
Drives: 2009 2 door hatchback Join Date: Aug 2009
I like the idea of the built in map sensor. Should work great when tuning under boost. What made you decide to tune with the AEM FIC instead of the Greddy Emanage ultimate? Are U tuning yourself or is the dyno shop tuning for you? Does this unit come with software to tune yourself? Is it a a pain in the ass to figure out how to make it work? Sorry for so may questions, I am puting together a turbo system for my Yaris and am trying to decide witch piggyback to go with Aem or Greddy. Also 1 more ?. Did you pull back timing at all?
#14 |
The main reason for using the AEM FIC was the map sensor. The way it works is that when the car is not seeing boost the AEM does absolutely nothing, and that is what is needed, the factory ECU is in control. When under boost the AEM takes over and does what you program it to do.
Are U tuning yourself or is the dyno shop tuning for you? Im tuning it myself. Does this unit come with software to tune yourself? Yes it comes with software Is it a a pain in the ass to figure out how to make it work? No if you have tuned piggybacks before Did you pull back timing at all? No, Im only pulling fuel since Im using the 1ZZ injectors |
#15 | |
C'est la vie
#16 | |
#1 Lemming
Drives: Light Blue '08 Yaris Join Date: Mar 2010
I'm really glad to see such a straight forward, no BS thread like this. Clears up a lot of confusion about boosting and will look forward to how this turns out.
#17 |
My car with the 1ZZ injectors & no correction from the AEM FIC runs rich. I am able to pull fuel with the AEM FIC to correct this rich condition while not in boost. Yes I have the check engine light on cause I have no catalytic. I tried to use a o2 fooler but it did not work. I use a o2 spacer as opposed to a o2 simulator which is electronic.
#18 |
C'est la vie
Thanks, I wont waste my time buying one of those o2s fooler tubes. I guess I will try the electronic version when its time. I would ask how the car starts when its cold, but your in Miami and your idea of cold is nothing like the arctic crap we have here in Chicago come winter time!
| Dyno results | PETERPOOP | Forced Induction Forum | 28 | 12-09-2009 11:01 AM |
| NST Sponsored Dyno Day In Houston | NonStopTuning | NonStopTuning | 24 | 10-05-2009 02:26 PM |
| dyno day | psychopinay42 | California | 1 | 08-03-2009 03:42 AM |
| Dyno and Videos | ruimond | Photo-Video-Media Gallery | 23 | 02-01-2009 07:34 AM |
| WR INTAKE SYSTEM : YOU GET $100 FOR DYNO RESULTS ! | WRLEO | Sponsors Classifieds Area | 0 | 02-22-2007 10:14 AM |
