Old 12-27-2013, 11:57 AM   #1
jayeh
Drives: '08 Yaris LB
Snow buildup in the wheel wells
Anyone else find this car absolutely awful for snow buildup in the wheel wells? My car has the 15" wheels and there is almost no room to kick the snow off between the wheel well and the tire.
I've taken to parking with the wheel turned to full lock and use a windshield scraper to get the snow off the car. I had two full shovel fulls of snow from my little car! It was a 24" shovel too! The other day I had to use a crow bar to pry the frozen back off my car!
It's the only car I've ever seen that routinely builds up snow around the tire that forms to the tire itself and almost goes down to the ground! Sometimes I swear it builds up to the point where it slows down the car!
Anyone figure out a solution other than scraping it off every time I park?
jayeh is offline   Reply With Quote
Old 12-27-2013, 03:38 PM   #2
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
I have the same problem with my 08 Yaris sedan, i dont understand why the snow gets so thoroughly jammed up in those wheel wells,poor design?
I do about what you do with the scraper.
Have Yaris will travel..
Old 12-28-2013, 10:11 AM   #3
Idahotom
Drives: 2008 5 sp. LB
I ignore it, as it doesn't really hurt anything near as I can tell.
Idahotom is offline   Reply With Quote
Old 12-28-2013, 12:38 PM   #4
Killchain
Killchain's Avatar
Drives: '10 Yaris LB Polar White
I don't live in Montana anymore, but I used to carry a toilet plunger stick to get the snow out. This works for big rig,wheel wells too.
Killchain is offline   Reply With Quote
Old 12-28-2013, 10:38 PM   #5
jayeh
The hardened show is so tough I had to use a 3' crow bar to break it off!
I miss Montana, and New Mexico. I want to go back.
Old 12-29-2013, 10:17 AM   #6
Killchain
Killchain's Avatar
Old 12-29-2013, 10:39 AM   #7
roxy1
Drives: 2014 yaris 5 speed
its been the same with every single small car I have ever owned. nothing unique to the yaris.
roxy1 is offline   Reply With Quote
Old 12-30-2013, 05:57 PM   #8
nookandcrannycar
Me too. I wish Ruidoso was closer to Houston. I'm used to Alpine skiing being no more than 200 miles away . Re the opposite end of New Mexico, I think that if someone told me I had to live the rest of my life in one town (but could have whatever I needed that I couldn't find locally sent to me, and could take day trips), that Red River, New Mexico (on the Enchanted Circle) would be pretty hard to beat. The physical beauty and the bounty of recreational activities alone, without considering other benefits, might be just about enough of a draw.
Old 12-30-2013, 05:01 PM   #9
nookandcrannycar
LOL. I have a friend who also no longer lives in Montana. He lived in Great Falls for many years. Your post reminds me of the myriad of things he told me he kept in his pick up to help with inclement Winter weather in Montana and the aftermath of same.
Old 12-28-2013, 10:55 PM   #10
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
You just need to stay on top of the situation. With today's car especially and how much the wheels/tires fill the wells you will see build up as an issue. I see it all the time with my friend's ford fusion, another friend's cobalt, and another buddy's eclipse. About the only vehicles I don't see it on is full size trucks. Even some SUVs I have seen this season have build up issues occurring. A lot of it I am gathering is also from the chemicals that they use on the roads.
Old 12-29-2013, 06:51 PM   #11
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Name:  snow yaris.jpg
here is mine being lowered dont help ....lol one just have to keep on top of it remove when possible.
Old 01-03-2014, 11:00 AM   #12
DebbyM46227
DebbyM46227's Avatar
Drives: 2017 Yaris IA, Pulse Red, Auto
We had 6" of snow yesterday and the temp this morning was ZERO. I was afraid to turn the wheels at all. I have thoughts of the ice chunks in the wheel well tearing my tires off the rims!! I care barely fit my big toe into the opening. Hopefully due to the sun being out today, I can stick a pole in there to get the snow out. Next Tuesday we are having 17 below zero temps so I need to get it out before then. I HATE WINTER!
DebbyM46227 is offline   Reply With Quote
Old 01-03-2014, 01:02 PM   #13
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Originally Posted by DebbyM46227 View Post
We had 6" of snow yesterday and the temp this morning was ZERO. ... I care barely fit my big toe into the opening. ...
If it's 0° out you should probably stop using your toes to measure things and put your boots back on!
Old 01-03-2014, 11:41 AM   #14
fnkngrv
fnkngrv's Avatar
You shouldn't ever have to worry about the snow build up causing damage to your tires. My biggest concern used to be damaging the plastic liners, but I fixed that by removing them. I haven't had them for 3 seasons now and have not experienced any rust or other detrimental issues.
At least with having plastic bumper covers front and rear it is pretty easy to bang off and remove build up once you figure out the method. Just don't try knocking on the upper wheel wells on the front cause you can easily put puckers in the body panel at the accent line...speaking from experience!
Old 01-03-2014, 02:21 PM   #15
I just leave it in there. Just like a bad tooth, it always falls out eventually.
Old 01-03-2014, 02:45 PM   #16
JustPassinThru
Drives: No more Yaris
What - your big toe?
JustPassinThru is offline   Reply With Quote
Old 01-08-2014, 07:32 PM   #17
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
Undercoating Your Inner Wheel Wells - How To ! Chris07LB Cosmetic Modifications (Exterior/Interior) 46 08-10-2012 11:17 PM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 10:16 AM
Does Anybody Find The Wheel Wells Get Packed With Snow. Mordarvia General Yaris / Vitz Discussion 28 12-09-2008 04:49 PM
