![]() ![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris sedan auto / Fit auto Join Date: Oct 2009
Drain and fill : Best to change ATF when cold ?
Would just drive up on ramps in the driveway . Read in manual it takes 2.6 qts. to refill ( 2 qts. 19.2 ounces ) . Last , would I need a new crush washer ? This is the 1st change at about 74,000 miles . Thanks
Although it is no where near as viscous as oil, I find that it flows out better when hot.
I have changed the fluid in three of them without changing the gasket, so I would say that it is fine for at least one change.
![]() Drives: 02 vitz rs Join Date: Feb 2014
hot ATF!!!! ctscott you're a sucker for punishment?
so many pedestrians..... so little time
Maybe that's why I have no skin on my right hand?
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 07:18 PM |
| DIY: CHANGE MANUAL TRANNY OIL | ttufrosty | DIY / Maintenance / Service | 157 | 09-07-2018 01:43 PM |
| ***The Engine Oil Bible*** | Hussain-Vtec | Performance Modifications | 20 | 09-28-2016 02:47 PM |
| ATF Drain and Fill | DMZ | DIY / Maintenance / Service | 7 | 05-30-2013 11:01 PM |
| Auto trans. drain and fill? | FochMan | DIY / Maintenance / Service | 5 | 01-07-2010 11:41 PM |
