Old 12-28-2009, 04:11 PM   #1
FochMan
Drives: 2009 Yaris HB
Auto trans. drain and fill?
Has anyone performed a drain and fill on thier auto tans. yaris? I'm thinking about doing my 09 every 30,000 miles. I'm talking about a simple drain and fill with Toyota WS fluid.
The owners manual says 2.6 qts.
Any tips? Has anyone seen a write-up on this procedure?
Thanks...
FochMan is offline   Reply With Quote
Old 12-28-2009, 04:43 PM   #2
MadMax
MadMax's Avatar
Search, I believe it's been discussed and the consensus was that it didn't need to be changed before 100K...if I am not mistaken, it is a "sealed" system...
Old 12-28-2009, 09:25 PM   #3
FochMan
thanks...
Thanks for the advise, but I've done the search and haven't found the procedure and don't want to do 100K intervals...
My car has a dipstick so I know it's not sealed...
Old 12-28-2009, 09:58 PM   #4
There's a drain plug on the bottom of the transmission pan, so you can drain it without dropping the pan. At 100K you'll want to drop it and replace the filter.
If you do a simple drain, you won't get the complete 3.1 quarts that it holds.
Old 01-07-2010, 07:01 PM   #5
N9QGS
N9QGS's Avatar
Send a message via AIM to N9QGS Send a message via Yahoo to N9QGS
I was told there is no filter its a metal screen, so you wont have to ever change a transmission filter, I have drained my transmission fluid 3 times, very easy to do and yes I have replaced it with toyota WS, cause I haven't found anything else approved that may be better. refill through dipstick, I buy 3 qts of fluid and you will have some left over.
198K Miles
N9QGS is offline   Reply With Quote
Old 01-07-2010, 11:41 PM   #6
The service manual and parts catalog show the automatic transmission filter as part number: 35330-0W020. It is metal strainer type filter, which traps particulate and is not designed to be disassembled to clean it. I replaced one of that same design on my Xterra recently.
There seems to be two schools of thought on these filters - Some say that they will last the life of the transmission and others say that they should be replaced at a regular interval.
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
how much oil do i do i fill with? wholenizz DIY / Maintenance / Service 11 07-17-2009 09:52 AM
