#1 |
![]() ![]() Drives: 07 yaris hatchy Join Date: Sep 2007
anyone know off hand how much oil is the right ammount to fill up after a complete drain? I just didn't know where to look
![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Dec 2008
roughly 4 quarts.
#3 |
![]() ![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
Not exactly for sure but I think it's somewhere between 3.6-3.8 qts.
#4 |
![]() ![]() ![]() ![]() Drives: '07 Yaris turbo, '11 Juke Join Date: Mar 2007
3.9 qts
http://www.cardomain.com/ride/3875996 |
#5 |
toyota
Drives: 2007 Yaris RS Blazed Join Date: Oct 2006
3.6 is more accurate.. 3.9 liters still left me with about .3-.4 left on it..
#6 |
awesome guys thx!!!
#7 |
Half a Bubble Off Plumb
Drives: 2009 Yaris Sedan Join Date: Mar 2009
Toyota says 3.9 quarts with the filter. 4's close enough.
That's U.S. quarts, not liters. |
#8 |
Drives: 2007 4 Door Yaris Join Date: Jan 2009
rtfm
#9 |
![]() ![]() Drives: 2008 Yaris HB Join Date: May 2009
3.7 or so, run the car then check again mine is always right at the top of the line. Draining while warm will help get the most amount of oil out, around 30 min after stopping the engine so its drained, but not so hot as to burn the crap outta your hand. Open the hood as soon as you stop to aid in cool off.
#10 |
i always fill up my oil filter like 75% with oil, then put it on, then i fill 3 5/8 quarts of oil =)
#11 |
![]() ![]() ![]() ![]() ![]() Drives: yaris 08 sedan Join Date: Oct 2008
Does no one read the owners manual any more?
#12 |
Drives: 07 Yaris Sedan Aero Join Date: Oct 2006
user manual says 3.7L this translates to 4qt.
| DIY: CHANGE MANUAL TRANNY OIL | ttufrosty | DIY / Maintenance / Service | 157 | 09-07-2018 01:43 PM |
| Synthetic Oil Questions. | Twistoffate0817 | General Yaris / Vitz Discussion | 19 | 07-15-2009 08:54 PM |
| Synth Blend Oils | scape | DIY / Maintenance / Service | 7 | 07-12-2009 01:55 PM |
| oil and oil filter question.. | marcus | DIY / Maintenance / Service | 27 | 07-11-2007 03:25 PM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 08:16 PM |
