Old 08-23-2014, 01:42 AM   #1
268i
Drives: 06' Yaris 1.3l
Why does it do this?
Hi everyone,
I've tried installing a pod filter on my Yaris (1.3l auto) this weekend but have been having some problems.
I use a spectre 8705 MAF housing,a silicone pipe reducer from 3" to fit the yaris orginal pipe and basic 3" pod from local autoparts store.
I start the car up and it idles at around 2500rpm, few seconds later the rpm's drop until under 1000rpm and the car shakes and the engine turns off. (Feels a lot like stalling a manual) Happens in about 10 seconds.
At the beginning I thought it was a faulty pod (restricting air flow) and left just the pipe on without the pod but the same thing occurred. Trying a different MAF sensor from my other toyota but the same thing happened. MAF sensor is positioned almost the same position as it was with the airbox.
Anyone had this happen before?
268i is offline   Reply With Quote
Old 08-23-2014, 06:34 AM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
Did the check engine come on?
When I removed my air box to do some maintenance, I had similar results. But it also threw a CEL. Something about MAF and intake temperature. I cleared it and it was good to go.
Old 08-23-2014, 05:37 PM   #3
268i
Check engine light only came on after engine died..
Old 08-23-2014, 07:28 AM   #4
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Your maf housing is the incorrect diameter. If its any different then stock the readings are skewed.
At least on our 1.5s the maf housing is 60mm-2 3/8" Yours is probably the same. Larger will run lean...smaller will run rich
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 08-23-2014, 05:39 PM   #5
268i
Oh, my MAF housing is 3"
But what I don't get is doesn't the ECU adapt to the difference in air flow etc over time.. (I have a fried also with 3" setup. )
Also, why does the engine shut off? AFAIK it should go into "Limp" mode..
Old 08-23-2014, 05:40 PM   #6
268i
Also worth noting that the first time I started the car i revved it a little and it got to around4000rpm but then the revs just slowly went down to zero
Old 08-23-2014, 05:47 PM   #7
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Did you unplug the battery to reset everything after you installed the intake?
But malibuguy is probably right. The Yaris is extremely sensitive to any changes. And MAF sensors can't deal with changes at all.
Colin Chapman disciple
Old 08-23-2014, 06:14 PM   #8
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
sounds like a vacuum leak , u sure u have everything connected right sensor facing the right way etc...
Old 08-24-2014, 01:32 AM   #9
268i
Yup. Sensor is pretty much in the same area and orientation as it was before.
Old 08-24-2014, 03:34 AM   #10
268i
I might try doing it again next weekend. I'll remove the battery this time and see how it goes. A friend of mine who did something similar said it ran quite rich for the first day or so..
Anyway.. Does the repeated experimenting with the setup (and causing the engine to turn itself of) pose any risks of damaging my engine?
Old 09-06-2014, 06:40 PM   #11
268i
Update: Battery removed this time and it seemed to shut off quite quickly. I've learnt from someone thats done this before that when the engine shakes I should leave it for the ECU to learn airflow as a result of it changing and to give it a little bit of gas if its really going to shut off. However, It was pretty much impossible for me to give it a little bit of revs before the engine just cut off..
Old 09-06-2014, 09:01 PM   #12
malibuguy
Obsessed with 1.5L
Im telling you from experience you need to change the maf housing to 2 3/8" /60mm
The stock computer does not have that kind of compensation built into it. Think about it...why the hell would the programmers waste time to create mappings for the off chance someone does incorrect modifications to the car??
-96 Tercel 4dr
Old 09-06-2014, 09:04 PM   #13
malibuguy
Obsessed with 1.5L
I had a xB1...same motor...I originally fabbed an cold air intake using 2.5" piping and it ran lean and had no power. Switch to 2.25" and it ran rich...measured the maf and realized what I needed to do. So I made a 2 3/8" housing and it ran beautiful.
The ecu is expecting only to see a basic range of parameters thru that sensor. The wrong size housing only skews what it thinks it is seeing
-96 Tercel 4dr
Old 09-06-2014, 09:27 PM   #14
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I was so glad when I ditched MAF. it has its place, but man it can be a PITA.
Old 09-06-2014, 11:08 PM   #15
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
x2 on the 2-⅜" MAF housing. The ECU will not compensate for any deviances in that diameter. It has absolutely no reason to either as Toyota engineered it to work with the stock air box and know exactly how much air flows by the MAF. Increasing the size of the pipe increases volume but decreases velocity, so the ECU see less air going into the engine and gives less fuel. There is no reason to increase it's size to try and get more air into the engine unless you've done MAJOR engine work and require it because you have a massive throttle body and it's opening is now bigger than the intake piping.
Old 09-07-2014, 12:37 AM   #16
fnkngrv
fnkngrv's Avatar
very nicely put.
Old 09-07-2014, 02:05 AM   #17
268i
Thanks everyone for advice. I bought the 3" housing all ready for the toyota MAF sensor and the company (spectre) only seem to make 3".. Might have to DIY with PVC Piping then..
Old 09-07-2014, 08:34 AM   #18
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Honestly don't get why u would have problem with size of piping cos when running a CAI on my Yaris with a 3 inch piping that shrinks down to 2.25 at throttle body it all works fine ...same as my Sri home made intake ...I say u have an issue with ur sensor .
Anyhow I see u got new piping let us know how it goes.
sent from my S4 on Mars
