![]() Drives: 2008 Yaris hatchback in white Join Date: Apr 2012
TPMS sensors question
I am buying some OEM 5 spoke aluminum wheels. The guy removed the TPMS sensors to use on his new wheels. I have sensors on my steel OEM wheels.
Both cars are '08 hatchbacks. It look like the tires must be taken off the rims to remove the TPMS sensors Can someone please verify this? I assume this just takes an extra minute but please correct me if its more complicated or requires any special mechanical skills. Thanks |
Yes you need to remove the tires in order to reach the sensors.
I am not sure the steel wheels use the same sensor than the alloy wheels though. |
Same sensors work for both wheel types. It is recommended that you replace the seals for the sensors when moving them to new wheels.
Can I use a regular valve stem on the aluminum wheels that originally came with TPMS sensors? The hole looks a bit larger...
Yes - Regular valve stems fit on TPMS wheels with no problem. I run a set that way.
thanks CT, is it possible to install the rubber valve without dis mounting the tire?
#7 | |
Are your tires mounted with no stems?
yes, they original owner dis mounted them to get the sensors for his new 18" wheels
then he had the tire put back on without a valve so I just have the holes... |
That's a bummer. I don't know why he would not have just had them slap a set of normal stems on them while the tires were off.
Most likely someone told him that new TPMS valves are 150$ and said just to reinstall the tires without them instead...
| TPMS Sensors... Do I need them? | EPyarisdriver | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 02-04-2012 09:01 AM |
| FS: Yaris steel wheels with TPMS sensors | ctrj | Items for Sale by private party | 4 | 11-29-2011 07:10 PM |
| TPMS Sensors with Toyota Alloys? | Lil Abner | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 06-20-2011 11:29 AM |
| Help Guys!! Wheel & TPMS Question! | Yaris4L1fe | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 03-26-2011 09:19 PM |
| TPMS sensors & Tire Size | kosko | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 03-13-2010 11:49 AM |
