Old 06-19-2011, 09:06 PM   #1
Lil Abner
Drives: 2009 3dr LB Manual
TPMS Sensors with Toyota Alloys?
I recently acquired some Toyota MR2 alloys for my car, and while at my buddies tires shop getting my tires swapped, we tried putting my TPMS sensors on the alloys. They fit, but there was a small air leak. The angle of the sensors is perfect, but the MR2 alloys didn't have a nice flat "seat" like my factory steelies had. I'm running now without the sensors until I can find a fix.
Anyone have any ideas? New softer seals? Different tapered seals? I'd like to keep the TPMS if possible.
Thanks in advance.
Old 06-19-2011, 11:11 PM   #2
thepartsmancometh
Drives: '08 LB, '07 WRX
As far as I know, you either get wheels designed with TPMS in mind, or disable it
thepartsmancometh is offline   Reply With Quote
Old 06-20-2011, 12:40 AM   #3
sex
sex's Avatar
Drives: 09 5DR
where was the leak? did you reuse the rubber gasket or metal washer or both?
Old 06-20-2011, 03:21 AM   #4
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
try just replaceing the old "O" ring on the sensors with a new one. Like a thicker "O" ring.
Old 06-20-2011, 06:32 AM   #5
Lil Abner
Yeah, I just took the sensors from my steelies, and placed them in the new rims. There was a SMALL leak at the inner-most spot of the seal. Right where the rim changes from vertical to horizontal. The seals do seem a bit stiff, so I'm going to order a new rebuild kit and see how "soft" those seals are. I don't need much, since they are so close already.
Old 06-20-2011, 08:32 AM   #6
ilikerice
ilikerice's Avatar
let us know what you find and if it helps
Old 06-20-2011, 11:29 AM   #7
Lil Abner
Will do. It might be a few months, since I'm trying to get the last 5-7k miles out of these tires.
Did Toyota Prius Driver Fake Unintended Acceleration? JBougie Off-topic / Other Cars / Everything else Discussions 33 03-15-2010 11:24 AM
Two Millionth Toyota Sold in UK VitzBoy General Yaris / Vitz Discussion 0 03-06-2006 03:52 PM
