Old 10-27-2014, 08:05 PM   #1
cap44
Drives: Yaris
Winter tires on a 07 Yaris
currently my 07 Yaris has 14" tires on it. Can I go with 15" rims and snows for the winter????
cap44 is offline   Reply With Quote
Old 10-27-2014, 08:20 PM   #2
mitchell12
mitchell12's Avatar
Drives: 2007 yaris HB
Yes, you could. 14's might be cheaper though. Plus having the extra sidewall helps on those days where you find obstacles buried in the snow
mitchell12 is offline   Reply With Quote
Old 11-10-2014, 09:39 PM   #3
MUSKOKA800
MUSKOKA800's Avatar
My 08 sedan came with 15" alloys and 185-60/15 rubber. I found used 14" steelies with winter boots (175-65/14) and find it a good package. It was cheaper when the boots needed replacement too. Ground clearance may be slightly increased with the 14's. This is good considering my drop. Less lip plowing is preferred.
Old 11-11-2014, 11:26 AM   #4
phaznet
phaznet's Avatar
Drives: '07 Yaris Sdn
I need winter tires! I've got an extra set of 15" steel rims in the garage. Car is on tein s tech springs, so 1.9" drop all around. What tire specs should I be looking at?
phaznet is offline   Reply With Quote
Old 11-11-2014, 12:32 PM   #5
fourbangingfun
fourbangingfun's Avatar
I, too, am dropped on s techs. I just put a new set of 185/60r15 Blizzaks on my spare set of steelies. We should have no problem with our drop and that tire size - especially on a stock steel wheel width.
fourbangingfun is offline   Reply With Quote
Old 11-11-2014, 01:39 PM   #6
phaznet
phaznet's Avatar
Thank you!
Old 11-11-2014, 02:20 PM   #7
IllusionX
Drives: 07 Yaris Sedan Aero
you can go with 175/65R15 for better snow traction instead of 185/60R15. but i'd say they both work well.
You actually sit a bit lower on 175/65R14, as the overall diameter is a bit smaller than 185/60R15. Personally, i went with 185/65R14.
06-10 Yaris Sedan cold air intake $40 kylevh21 Items for Sale by private party 2 04-01-2012 02:14 PM
FS: oem 14" steelies w/ winter tires thebarber Items for Sale by private party 5 03-31-2010 11:16 AM
2007 Yaris bad tires weaver615 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 03-27-2010 07:21 AM
Winter Tires? sketch182 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 10-23-2008 06:47 PM
