![]() Drives: yaris 2013 (LE) Join Date: Dec 2014
195/50/16
Will 195/50/16 fit yaris 2013 LE model ?
Kindly give your reviews thanks :) |
![]() ![]() ![]() ![]() ![]() Drives: 2014 Yaris SE Join Date: Apr 2014
The SE has 4 wheels discs and the front discs are slightly bigger than the LE model. Also different suspension tunings. But none of that affects the tires. Of course you need 16" wheels as well as the tires. LE wheels are 15" stock.
Thanks man ^^
I was really confused
195/50/16 is a JDM OEM fitment.
* Many folks fit 205/50/16's because they are a more common size offering more brand options. 205/50/16's work very well on the car. Last edited by kimona; 07-08-2015 at 05:21 PM. |
Once again, it is all about the offset.
![]() ![]() ![]() ![]() ![]() Drives: '15 Yaris SE 5MT Join Date: Jun 2014
Is it best to go with a 16 x 6.5 (versus 16 x 7.0+) aftermarket alloy wheel for my 2015 SE, if I plan to stick with 195/50/16 or 205/50/16 tires? I assume the lighter weight of the 16 x 6.5 wheel would be preferable, and closer to the OEM 16 x 6.0 wheel sizing. All the designs that I like (located in the U.K.) are x 6.5 or x 7.0 sizes only, so OEM x 6.0 isn't even an option.
What offset should I be looking for with those wheel/tire sizes? On a side note, Tire Rack (and U.S. Distributors) seems to have a very limited selection of conventional/traditional wheel styles, compared to various U.K. alloy wheel stores. It looks like I will have to pay for international shipping rates to get the wheels I like.
| Which way i go? I will be on 16x7.5 +35mm rim. Will i be on 205/50/16 or 195/50/16 | daddz07 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 03-15-2014 02:12 AM |
| FS(NJ): Lightly used 195/50/16 Bridgestone Turanzas | NJ Drive | Items for Sale by private party | 16 | 05-29-2013 02:22 AM |
| Summer Tires 195/50/16 (2) Options? | derickveliz2 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 04-01-2013 01:57 PM |
| 16x7 - 40mm offset - 195/50/16 rubbing like a fat kid at a Rave | 3cyltrbo | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 04-14-2011 03:42 PM |
| 195/50/16 or 205/40/17? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 10-18-2009 05:17 AM |
