Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
Rear mail oil seal replacement
First, please dont use my milage for referance. Because my car sees regular autocross action and track time, my 178,000miles is not the same as a daily driven only 178,000miles.
After autocross one weekend I noticed a drip of oil under my car, I jacked it up and saw this... |
I don't recall where this is.
Mine had a leak around the timing chain cover. Redid the silicone seal, and replaced head gasket whole this was open. Edit: here is my leak.. ![]() Sent from my A0001 using Tapatalk |
#3 | |
![]() ![]() ![]() ![]() Drives: 2009 5-door, 5-speed Join Date: Sep 2011
Cheers. |
Data doesn't lie
I check my compression regularly, and I have a catch can. There are no other leaks and this leak gets worst when you drive the car vs idling, a indicator of a RMS leak.
Data doesn't lie
Here is the old seal, you can see its not in goodshape, its also a bit hard where it should be flexible
OK. Looks like you got it well in hand. That seal is definitely not happy. I'm doing a clutch tomorrow on mine but I don't think the RMS will be needed. Same sort of life, but much less mileage.
Cheers. |
| Oil filter seeping oil from seal : Should I change it ? | Hershey | DIY / Maintenance / Service | 33 | 11-14-2012 04:25 PM |
| Did I overfill my oil? | zkay | DIY / Maintenance / Service | 10 | 06-20-2012 10:59 AM |
| Ultra Racing 23mm Rear Stabilizer Bar | Loren | Performance Modifications | 62 | 05-18-2009 07:20 PM |
