Scraper
Drives: '08 Yaris RS 5-Door Join Date: Nov 2014
Camber Bolts
Looking at running some negative camber up front come summer. What options are out there and which will get me the most aggressive camber? Looking for around -5 degrees if possible.
Thanks. |
![]() Drives: 2007 Yaris Sedan Join Date: Nov 2015
I don't have much experience with camber bolts but iirc each bolt only gets you roughly 1° , and you can only use 2. May have to look into an adjustable top hat from Cusco(or equivalent) to get the 5° you're after.
I run the TRD Camber bolts. Think the max you can get is just under 3*. If you want more, you may need to elongate the camber bolt hole in the strut. I don't recommend doing this. Maybe some more research out there will help. A lot of the camber bolts are interchangeable between toyota cars with same designs.
Pumpman
Drives: 2019 Kia Soul EV Base Join Date: Dec 2014
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog |
![]() ![]() ![]() ![]() ![]() Drives: 2015 H Production Yaris Join Date: Oct 2009
A pair of SPC bolts (upper and lower hole) should be good for around -4 if you have lowered your car some. Much of anything over -3 to -3.5 is excessive and doesn't do much for you unless you are in to that "look".
http://www.spcalignment.com/spc-performance
2005-2008 SCCA Solo BS National Champion 2017-2018 SCCA H Prod National Champion
![]() ![]() ![]() ![]() Drives: 2009 5-door, 5-speed Join Date: Sep 2011
I'm guessing you've never tried two? I'm just curious if two skinny bolts would handle track-days or not. It's general considered unsafe to have two skinny bolts in there.
One SPC bolt will give -2.8° btw. I can't see needing any more than that for performance. |
#7 | |
When we first built the B-Spec cars we used two of the smallest OE crash bolts in each strut, was good for about -2, never slipped. Even with this hit, which broke the wheel, the bolts did not fail - although they did slip, so I replaced them, along with the control arm, spindle, axle, ect. ![]()
Good to know they don't slip (except when stuffing it
).Odd. I got -2.8° out of just one bolt on my 09 5dr (and shifting subframe/ctrl arms). Cheers. |
#9 | |
I did not stuff it, a CRX tried to ride shotgun. Watch from the 46min mark: http://www.scca.com/videos/1972492
| WTB: Adjustable camber bolts and rear camber shims | Supra_Yaris | Willing to Buy by private party | 6 | 03-21-2015 06:16 PM |
| anyone currently running two sets of camber bolts? | DeathBeard | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 02-06-2013 01:37 AM |
| adjustable camber bolts? | b20vteg | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 08-22-2012 10:08 AM |
| Adjustable Camber Bolts | Kendrik | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 0 | 10-31-2011 02:29 AM |
| Are camber bolts needed after installing springs? | CtrlAltDefeat | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 02-01-2009 12:19 AM |
