![]() Drives: 2009 Yaris Join Date: Mar 2016
Electrical Problems
Hi guys so I cannot figure this out for the life of me maybe you guys can help me out. I have a 2009 Yaris and changed the oil replaced the spark plugs and when I replaced the spark plugs I removed the battery terminals.... Went to start it up everything was fine and about couple days later the dash lights came on, abs,power steering, battery light so I was ok maybe it was the alternator... So I replaced the alternator and ran good for another couple days and next thing I know all those lights come back on!!! The belt is tight just can't figure it out... Is it a fuse? Any help or wisdom would be kindly appreciated!
I also bought a new battery as well...
Check the fusible links on the positive battery terminal
just checked the fuseable links and there fine...
Think autozone gave me a junk alternator because I returned it installed the new one fired it up and no abs p/s lights at all... Drove it around for a hour think it solved the problem
| Electrical Problems PS,A/C,RADIO,SPEEDOMETER,SIGNALS,AIR BAG LIGHT ON, ALTERNATOR | toystory | DIY / Maintenance / Service | 43 | 04-17-2021 04:54 AM |
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 01:15 AM |
| 09 Yaris Electrical Problems (P/S, ABS, AC, Speedo, Blinkers, Wipers Not Functioning) | garrettbeachy | DIY / Maintenance / Service | 2 | 08-20-2015 01:19 PM |
| follow up on 2010 yaris problems + more problems | heavenswaitin | DIY / Maintenance / Service | 18 | 09-03-2013 03:47 PM |
| Starter (or possibly electrical) Problems with 2008 Yaris Sedan | amandadalton | DIY / Maintenance / Service | 6 | 11-21-2012 05:32 PM |
