Old 03-22-2016, 10:36 AM   #1
xdr3amx007
Drives: 2010 Toyota Yaris Sedan
Question Driver side reverse light power issue
Hi all, I'm having issues with the driver side reverse light on my 2010 yaris sedan. The light was out when I purchased the car; I know the vehicle was in a rear end collision and the taillamp was replaced with an aftermarket unit. I tried replacing the bulb with a new bulb and that didn't work. I tried moving the bulb and holster for the passenger side (working) to the driver side, and that didn't work either. I used a multimeter to check the connections on the light while activated (car in reverse) and it was reading less than 3 DCV, while the working passenger side read 12.5 DCV. So, for some reason, it appears that the driver side is not getting enough power. Any ideas?
xdr3amx007 is offline   Reply With Quote
Old 03-22-2016, 02:44 PM   #2
jack black
jack black's Avatar
Drives: 2007 red Yaris HB AT
damaged wiring or loose plug.
jack black is offline   Reply With Quote
electrical, tail lights, taillights
Help ! Front passenger side power door issue. valchrist90731 DIY / Maintenance / Service 4 07-16-2015 05:11 PM
Very strange clunking from driver side tire - everything tried so far no go? (2007) KorJax DIY / Maintenance / Service 22 12-09-2014 02:50 PM
Reverse light vs Rear Fog light cooldavidko General Yaris / Vitz Discussion 3 01-03-2007 03:09 AM
"Airbag" center console light on 07 Sedan with side airbags atebit In Car Entertainment + Electronics (audio / video / alarm) 5 11-10-2006 06:10 PM
