Old 07-16-2015, 01:59 AM   #1
valchrist90731
Drives: 2007 toyota yaris sedan
Question Help ! Front passenger side power door issue.
Power door locks the door, but does not unlock. All other locks are fine. Just that front passenger side door.(front right door).
I hear and see all doors lock but when i press to unlock no sound at all for that right front door.
2007 yaris sedan i only have two lock switches located in the front side doors.
Please need insight on this.
valchrist90731 is offline   Reply With Quote
Old 07-16-2015, 05:45 AM   #2
sex
sex's Avatar
Drives: 09 5DR
www.yarisworld.com/forums/showthread.php?t=44694
Old 07-16-2015, 12:40 PM   #3
valchrist90731
Is it really the door lock actuator?
I read the post you sent.
I'm not sure if this is the problem
because the door does lock from this particular door! from the inside. And unlocks and opens with a key from the outside.
I just doesn't lock when i push that switch to unlock it from the inside front passenger side door.
The thread you posted deals with a person who can't get the door to open or closed from a particular door from the inside.
I just can't unlock it from the inside.
If you need more details please ask.
Old 07-16-2015, 04:08 PM   #4
It may still be the actuator. It may also be binding of the cable to the manual lock lever. The key directly flips the lock assembly, so it really is not a good test. If you use the manual unlock lever inside does it feel stiffer than the driver side?
Old 07-16-2015, 05:11 PM   #5
valchrist90731
This morning i tested the lock and it works now.
This is so weird.
Thanks i will check soon.
WTB: Passenger Side Foglamp white_rice Items for Sale by private party 3 03-18-2012 09:28 PM
A/C only blowing out of passenger side? devinlamothe DIY / Maintenance / Service 24 08-08-2011 05:50 PM
New carbon fiber front lip and side skirts. Yaris PAVEL94 Cosmetic Modifications (Exterior/Interior) 17 12-19-2010 03:01 PM
How hard is it to remove side skirts and front lip on 08 sports package? dono37 Cosmetic Modifications (Exterior/Interior) 15 09-26-2007 05:28 PM
