Old 07-21-2016, 06:03 PM   #1
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
Larger condenser for stock A/C?
Out of curiosity, has anybody thrown in a larger condenser and did it provide more efficiency in the system?
This is assuming you do everything like adding more refrigerant (recharging) and what else to compensate for the larger volume.
Old 07-24-2016, 07:57 PM   #2
jra
Drives: 2015 yaris L
I don't think if it would make a difference without putting a larger evaporator in to go with it. There's a temperature switch at the evaporator, a small tube stuck to the evaporator with some black gooey stuff that will turn compressor off a little above 32 degrees to prevent ice from forming on evaporator. so to get a larger volume of cold air would require a larger evaporator.
jra is offline   Reply With Quote
Old 07-25-2016, 01:26 AM   #3
rningonfumes
The evaporator....takes a bit of time to get to. LMAO!! https://youtu.be/IJmXqeTFtuU?t=161
Also, it's a finite space.
I was just thinking of the condenser because of ease of access.
Old 07-25-2016, 10:43 PM   #4
SirDigby
Drives: 2007 yaris 3 door
yes. you would need a larger/multiple evaporator, condenser, and larger/multiple compressor. your local luxury limo rental place will know all about this.
I have a local limo place that in their suburban limo they run 3 compressors and 15 lbs of refrigerant. I told them that's more than the city busses run! (they are around 5 lbs)
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 05:00 PM
Replaced my A/C condenser villdemar DIY / Maintenance / Service 5 05-28-2016 03:13 PM
A/C Clutch Compressor question tmontague DIY / Maintenance / Service 3 05-11-2014 08:57 AM
Just replaced my A/C condenser, now what? Astroman DIY / Maintenance / Service 5 04-02-2014 06:26 PM
A/C Compressor failure causes.. DaninTexas DIY / Maintenance / Service 0 07-07-2013 09:18 PM
