Old 07-07-2013, 09:18 PM   #1
DaninTexas
Drives: 2007 Yaris 4 dr
A/C Compressor failure causes..
My wife hit a deer head on with her Yaris and had it fixed at a local shop per our insurance company's instructions. A/C condenser had to be replaced along with various body parts. Here's the interesting part: when we got the car back the A/C worked intermittently where it had worked perfectly before the wreck. I took it back to the shop (which is not an A/C shop) and they diagnosed the problem as being with the condenser they used - they used an aftermarket part. So they replaced it with a Toyota condenser. Now the A/C doesn't work at all. They told us that the compressor was bad and that it was just bad luck. I bought a set of gauges and the readings are: Low 115 psi and High 125 psi. They did not replace the receiver drier. The compressor clutch engages. My question is this. Could the repair shop have caused the compressor to go out or is it all coincidence?
Thanks ahead of time. I've learned a lot by lurking on here.
Dan
DaninTexas is offline   Reply With Quote
a/c compressor
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 05:00 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 10:17 PM
A/C compressor yaryar83 General Yaris / Vitz Discussion 3 06-03-2012 10:47 PM
A/C Broken On My 2010 5 DR HB ChilliwackGuy DIY / Maintenance / Service 15 07-14-2010 05:33 PM
Easy Defrost A/c running fix billk General Yaris / Vitz Discussion 14 01-16-2009 09:53 PM
