![]() ![]() Drives: Yaris 12 Join Date: Oct 2016
RCA output
Hello,
Do you know if this radio has an RCA output? (2012 Yaris L 3rd gen, 2 doors) Thanks Alain Last edited by Alain93; 02-25-2017 at 02:02 PM. |
rear speakers wire color
Ok so no RCA output on this unit.
Do you know the wire color for the rear speakers? Is it the same as 2007? |
I will hook up the LOC following the color scheme of the 2007 (see sticky).
If everything explode, I will tell you, if still alive
here is the back of the stereo, is it the same as the 2007?
No? Nobody?
I think I going to buy back my Saab. |
So, thanks for your help everyone.
I hook up the LOC on rear speakers output +Black -Yellow and it's working fine. Now I can run RCA cables to my amp. I used the gray wire for the LOC 12v. Everything is working good thank you. |
![]() Drives: Yaris 2012 Join Date: Sep 2017
HI Alain93, could you help me where I can find wire cable for Remote many people say color Blue, to connect to Ampli
Sent from my E6653 using Tapatalk |
Hi ibadtaylor,
Blue is for 12v to the radio, I used the grey to switch my amp on/off. I'm not using Loc anymore, I changed the HU. |
Hi Alain93,
Thank you for your reply on my question, but before you changed your HU is that working using Grey to switch your amp on/off? What kind of LOC do you use, can you show me the model of LOC?, thanks before Alain93 ;) Sent from my E6653 using Tapatalk |
| Remote Starting | xairmech | DIY / Maintenance / Service | 35 | 01-22-2020 10:10 AM |
| Increase alternator output or adjust idle? | mazilla | In Car Entertainment + Electronics (audio / video / alarm) | 10 | 05-28-2011 12:49 AM |
| Viper Alarm Install | gwasabi | In Car Entertainment + Electronics (audio / video / alarm) | 28 | 08-11-2010 02:57 PM |
| Parking Light Flash Output vs Hazard Light Output | sex | DIY / Maintenance / Service | 2 | 11-03-2009 08:47 PM |
| Extra Output signal from OEM deck | charleschia1986 | In Car Entertainment + Electronics (audio / video / alarm) | 5 | 09-28-2009 12:28 PM |
