Old 10-29-2008, 04:02 PM   #1
gwasabi
Drives: 07 Blazing Blue LB
Viper Alarm Install
I was wondering if anyone was willing to help me with the wiring with my alarm install. If anyone is I will post the alarm's installation guide with all the wires. Can you just point me to where the wires would go to on the yaris electrical guide? thank you in advance!
gwasabi is offline   Reply With Quote
Old 10-29-2008, 04:35 PM   #2
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
12volts yellow (25A), gray (15A) + ignition harness
Starter black (x2)(common) + ignition harness
Second Starter N/A
Ignition pink + ignition harness
Second Ignition green + ignition harness
Third Ignition N/A
Accessory white + ignition harness
Second Accessory N/A
Keysense yellow - ignition harness
Notes: Using the status output from the remote start to trigger this wire will disarm the factory alarm without unlocking the doors.
Power Lock brown - driver kick, 20 pin plug, pin 7
Notes: Meter this wire while turning the key in the driver door key cylinder.
Power Unlock yellow to green (double pulse) - driver kick, 20 pin plug, pin 8
Can also use the passenger door key cylinder unlock wire, which only requires a single pulse. It is green (-) at the fuse box, middle, 18 pin plug, pin 15.
Lock Motor white to orange 5wi driver kick, 20 pin plug, pin 10
Unlock Motor lt. blue to pink 5wi driver kick, 20 pin plug, pin 20
Parking Lights+ green + fuse box, top L, 30 pin plug, pin 29
Parking Lights- white - headlight switch
Notes: Not available on all models.
Hazards black - hazard light switch
Turn Signal(L) lt. green + fuse box, top L, 30 pin plug, pin 27
Turn Signal(R) yellow + fuse box, top L, 30 pin plug, pin 28
Reverse Light red + fuse box, top L, 30 pin plug, pin 30
Door Trigger see notes - fuse box, top left, 30 pin plug
Notes: The LF door is red in pin 21. The RF door is blue in pin 24. The LR door is green or yellow in pin 5. The RR door is blue in pin 20. The rear doors are common on some models. Use all four wires and diode isolate each.
Dome Supervision pink - fuse box, L side, 6 pin plug, pin 2
Trunk/Hatch Pin lt. blue - fuse box, top L, 30 pin plug, pin 7
Hood Pin white - pin sw or theft warning ECU, pin 4
Notes: The theft warning ECU is behind the glovebox.
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock use key sense wire
Tachometer lt. green ac data link conn. under dash, pin 9
Wait to start N/A
Brake Wire green to purple + fuse box, top L, 30 pin plug, pin 12
Parking Brake yellow - fuse box, top R, 16 pin plug, pin 2
Horn Trigger black to lt. green - fuse box, top, 36 pin plug, pin 28
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes: Optional on the sedans and S sedans, not standard equipment.
Smart Starter Kill Relays: Not Available
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Old 10-29-2008, 04:51 PM   #3
bobby
bobby's Avatar
Drives: 2007 Yaris/2009 Phit Sport
Alarms
A waste of money, and just more noise pollution! Who's going to steal a YARIS for God's sake?? Buy a Club.
bobby is offline   Reply With Quote
Old 10-29-2008, 05:17 PM   #4
gwasabi
I actually just want the door lock features but since I got the alarm might as well right? hahahah THanks Version but I have like almost no idea but I'll post up the guides if its alright with you can you advise me to which wire goes where? thank you!
Old 10-29-2008, 05:24 PM   #5
gwasabi
Old 10-29-2008, 05:39 PM   #6
gwasabi
PRIMARY HARNESS--------------
- 200mA TRUNK RELEASE OUTPUT
+ 12v CONSTANT INPUT
+ SIREN OUTPUT
LIGHT FLASH -ISOLATION WIRE- PIN 87a of onboard relay
- Chassis Ground (to ground)
+ Door Trigger Input
- Trunk pin/instant trigger input
- door trigger input
- 200mA dome light output
- remote start/ turbo timer activation input
parking light output
- 500mA ground when armed output
Auxiliary HARNESS--------------
- 200mA factory alarm disarm output
- 200mA factory alarm arm output
- 200ma aux 1 output
- 200ma aux 2 output
- 200ma aux 3 output
- 200ma 2nd unlock output
- diesel wait to start input
- 200ma horn honk output
door lock harness -------------------
+ lock - unlock output
- lock + unlock output
heavy gauge remote start ------------
+ignition 1 input/output
30a fused ignition 2 / flex relay input 87
accessory output
+ starter output(car side of the starter kill wire)
+ starter input (key side of the starter kill wire)
+ fused 30a ignition 1 input
+ ignition 2 / fles relay output
flex relay input 87a key side (if required) of flex relay
fused 30a accessory/starter input
REmote start input-------------------
- neutral safety switch input
- tachometer input wire
+ brake shutdown wire
n/o or n/c - hood pin switch input zone 6
- 200ma 2nd status/rear defogger
remote start auxiliary output ------------------
- 200ma flex relay control output
- 200ma accessory outpt
- 200ma starter output
- 200ma ignition 1 output
- 200ma status output
Old 10-29-2008, 05:40 PM   #7
gwasabi
hats eveything in the book can you write which wire and location the wire should be connected to? appreciate it very much! This is for a viper 5701 remote starte alarm model btw. This should be stickied if anyone can help me out. Also i'll give you 6 pack if your ever in hawaii! hahahaha THANKS GUYS!
Old 10-29-2008, 06:30 PM   #8
battleversiontc
im actually in honolulu and install alarms on the side use to be a best buy district mobile install lead
this is for a remote start alarm
h3 10pin harness red, red/white, red/black splice together
h3 10pin harness violet
Second Starter N/A
h3 10 pin harness pink
h3 10 pin pink/white
Third Ignition N/A
h3 10 pin orange
3 pin harness green
3pin harness blue
h1 12pin white
h1/8 12 pin green
Wait to start N/A
5 pin harness brown
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Yes Type:
Transponder
Part #: 556UW
you still need to keep the h1/3 siren output wire(brown) h1/5chassis ground(black) h1/2 12v input just splice into the remote start constant wire (red) remote start input you need neutral safety (black/white) just ground it,
then thats pretty much it besides you gotta program it but where you at im free on thursday so let me know where you be or private message me a number i can help you if this all seems to be a blur
Old 10-29-2008, 06:35 PM   #9
battleversiontc
not here in hawaii they take anything they can get there nasty hands on so long you got good stuff in it they going try take yo sh!t and clubs dont work you can actually break them damn dont you watch tv or do research on things
Old 10-29-2008, 06:45 PM   #10
gwasabi
whats your favorite beer!
OPh and let me know what I need.
so far I get the crimps and the shitty walmart crimper. I also get couple wire taps and some other stuff. Wire hanger I got. I dont have a voltage meter tho :(
Old 10-29-2008, 06:45 PM   #11
gwasabi
YEa in Hawaii you leave your vehicle in the wrong place, they'l jack everything that's not tied down. even the half worn tires hahaha
Old 10-29-2008, 07:50 PM   #12
battleversiontc
haha brah sorry no drink beer only soda but i get everything you dont have i normally carry my bag of tools around with me so you no need worry i got you covered
Old 10-29-2008, 07:52 PM   #13
battleversiontc
haha sad but try about the tires haha then you come back and yo sh!t is on bricks or rockin the slammed look on yo rotors lol
Old 10-29-2008, 08:37 PM   #14
bobby
bobby's Avatar
That's too bad. Unfortunately, alarms aren't much of a deterrent.
Old 10-29-2008, 08:41 PM   #15
battleversiontc
wow so negative geez
its alot better then a club. plus to if you have an alarm when they go to jack your ride up it will go off so atleast someone may notice
Old 10-29-2008, 11:42 PM   #16
sportin83
Drives: 2008 blazing blue yaris LB
alarms do help but if someone wants something bad enough they are gona try anyway.
http://cardomain.com/ride/3151056
mods: custom sub box, i hit 141.4 db, new speakers, double-din nav, foglights, cruise, CAI, strut brace, under car braces, short antenna, remote start, alarm, actuators in doors and hatch
coming soon: window tint, custom sub grills, tach and........
sportin83 is offline   Reply With Quote
Old 10-30-2008, 12:12 AM   #17
battleversiontc
true dat
Old 10-30-2008, 12:15 AM   #18
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
club. HAH. they can just saw the wheel and take it right off.
Keep your vehicle protected! sqcomp In Car Entertainment + Electronics (audio / video / alarm) 17 09-10-2009 02:02 AM
Viper Alarm install gwasabi DIY / Maintenance / Service 0 10-29-2008 03:54 PM
alarm install acrbill In Car Entertainment + Electronics (audio / video / alarm) 3 12-18-2006 03:17 AM
power locks and alarm install acrbill In Car Entertainment + Electronics (audio / video / alarm) 1 12-01-2006 12:17 AM
alarm install Lowfront In Car Entertainment + Electronics (audio / video / alarm) 5 09-12-2006 06:32 PM
