Old 03-06-2017, 06:22 PM   #1
frank2005
Drives: Toyota Echo RS 2005
Echo vitz hatchback change oil without jack ?
I'm not equipped
The street is my garage lol
It is possible to change the oil and filter without jack on Echo hatch ?
I try, and i am able to touch the oil filter and drain plug
Seems possible
frank2005 is offline   Reply With Quote
Old 03-06-2017, 07:32 PM   #2
bronsin
bronsin's Avatar
It might help to put one side of the car up on a curb.
Lifelong Shade tree Mechanic
Old 03-06-2017, 09:39 PM   #3
toad
toad's Avatar
Drives: street-legal go-kart
this^ just make sure to get the left side 'up' as the oil will drain more completely.
toad is offline   Reply With Quote
Old 03-06-2017, 07:53 PM   #4
scratchpaddy
Hubcap Enthusiast
scratchpaddy's Avatar
Drives: '09 3-door 5-speed
I don't have any issues changing my oil without a jack, in the parking lot of my apartment complex. Mine is a '09, but the engine is the same. The drain plug is right there on the side, instead of in the back like most cars. Makes it really easy to reach. The oil filter is easy to grab, too. Heck, it's safer to skip the jack, anyway. No chance of the car falling on you.
Go for it.
scratchpaddy is offline   Reply With Quote
Old 03-07-2017, 11:08 AM   #5
frank2005
Go for it.
is it true
It is necessary to change oil to hot temperature
Not burning temp, but hot
cold is not good
Old 03-07-2017, 11:37 AM   #6
bronsin
bronsin's Avatar
Originally Posted by frank2005 View Post
is it true
cold is not good
you need to apply the Goldilocks Rule
Not too hot, (burns!) not too cold (doesnt contain all impurities)
JUST RIGHT! (warm)
Old 03-07-2017, 10:10 AM   #7
if its stock, you might be able to swing it
mine is on eibach prokits so its a tad low to get a pan under the car
Old 03-07-2017, 02:13 PM   #8
dogsridewith
Drives: 2007 2-door hatchback
fast fluid drains hot
I set up everything for all fluid changes after a drive. Then rev engine and drain as quickly as possible. Oil going into the oil pump's relief valve is unfiltered and a tiny piece of junk wedged just right could jam a piston type valve open and kill oil pressure.
The less that settles the best.
(obviously must be done avoiding hot fluid on skin)
Should i change transmission oil? Dreamy General Yaris / Vitz Discussion 24 08-15-2025 09:08 AM
Jack Stands, Floor Jack and Oil Filter? 268i DIY / Maintenance / Service 11 08-03-2014 04:32 AM
Help with oil change specs autophile DIY / Maintenance / Service 31 04-25-2011 09:22 PM
Synth Blend Oils scape DIY / Maintenance / Service 7 07-12-2009 01:55 PM
Who here has done oil change without a jack??? Yawesh General Yaris / Vitz Discussion 38 01-02-2009 08:06 PM
