Old 04-17-2017, 06:29 PM   #1
AzianCuz
conundrum562
AzianCuz's Avatar
Drives: Toyota Yaris 2007 S
Exclamation Battery/Gear Light Flickering & Alternator Not Charging
01. Power Relay was stuck. Basically when I turn the ignition to off, the car would still think it's on ACC or Accessory mode, since it was stuck.
02. The whole fuse junction box, below the driver steering wheel had to be replaced. I got a used one for $290 dealership would have been $500-$700.
03. After this was replaced, I noticed that my battery indicator was flickering crazy and my gear light on the cluster was doing the same thing. Finally my alternator gave out.
04. Found out it was from a green wire that was in the fuse junction box. That mechanic probably "Cut It" for reasons unknown... Maybe wanted to make more money off of me, who knows. Not here to judge.
05. My other friend mechanic clamped the wire back together and now there's no more intermittent flickering and the alternator is now charging the battery.
[IMG][/IMG]
BLITZ SC | CERAMIC 6301 BEARINGS | MICRO-IMAGE CRANK | NST PULLEYS
TRD 71C THERMOSTAT | 1ZZ INJECTORS | TB SPACER | BLITZ SRI
NGK PLUGS, COILS & MAF | DC HEADERS | CUSTOM 2.25" EXHAUST
GTSPEC STRUT BAR, MID & 4-PT LOWER BRACES
TANABE FRONT & WHITELINE REAR SWAY BARS W/ POLY BUSHINGS
TBW SKID PLATE | FULLRIVER AGM BATTERY | MOBIL 1 EP + PROLUBE
AzianCuz is offline   Reply With Quote
alternator, battery, battery indicator, battery light, flickering
DIY yaris III fog lights installation karloslatynos Third Gen Yaris General Discussion 54 04-24-2026 08:40 PM
yaris 2009 charging light problem ASEMX1 DIY / Maintenance / Service 1 02-13-2015 08:33 PM
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 01:50 AM
Charging System Light N9QGS DIY / Maintenance / Service 1 07-26-2010 06:53 PM
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
