Old 02-13-2015, 08:08 AM   #1
ASEMX1
Drives: Yaris sedan 2009
yaris 2009 charging light problem
greeting everyone ...,
i have problem on my yaris 2009 charging , from 3 month's the battery light flashed randomly and the headlight and horn starts to reduce lighting like the battery dies all that the engine running , and finally the car didnt start .
i checked the battery and its good and
checked the alternator regulator and its fine,
checked the alternator voltage its fine also
, changed the alternator the same problem
, checked the fuses all good
i changed the alternator with corolla 2007 alternator its fine but the battery lighted very low light
what i do ?????
sorry for my bad language
ASEMX1 is offline   Reply With Quote
Old 02-13-2015, 08:33 PM   #2
If you replaced the alternator and the battery dying problem went away, then you had a bad alternator. The 07 Corolla alternator probably doesn't output the correct signal that the Yaris cluster wants to see and that is why the battery light is on dimly.
Yaris 2 D4D 2009 without AC serpentine belt rasyaya DIY / Maintenance / Service 6 07-17-2014 09:02 AM
Yaris TR 1.3 '08 AC problem Eeman DIY / Maintenance / Service 5 07-03-2014 04:59 PM
06-10 Yaris Sedan cold air intake $40 kylevh21 Items for Sale by private party 2 04-01-2012 02:14 PM
