![]() ![]() ![]() Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
Give me opinion on coilovers
I have performance shock and struts, of course their not adjustable...they are stiff of course with 2" drop...
will coilovers be different than performance shocks strut other than adjusting heights and control soft - hard? i was trying to purchase set of coilovers and some of the people i know said it should be almost no difference since you got performance shock and springs Sent from my SM-N920C using Tapatalk
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem
I've only ran performance struts and could but from reading many forums of others whom have done both the consensus seems that a good quality set of struts and could will out perform a poor or mediocre set of coil overs.
Most people say if you want the adjustment then get co's but you need to pay to play. Usually above $1k is where you get the decent quality co's. Armstrong was running to kill blues and micro image springs. He'll be running some BC co's Nina few weeks so watch out for his review as that will be a great compassion
Nice! Gotta love spell check.
Good spring/shock/strut combo all the way. Quality coilovers are way too expensive for what the average person requires.
#4 | |
Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
I ordered a custom set of BC DR coilovers, it will take then 2-4 weeks to build them and they were well over $1000 Sent from my SM-G955U using Tapatalk |
My fat fingers hit every Damn key...
But I agree, $1200USD and up is a very steep price to pay unless you track your yaris and need it corner balanced/constantly need to adjust height and dampening Tried and true bilstein b8's can be bought off eBay for less than $400 USD and there are a plethora of great lowering springs for our car
Koni makes adjustable shocks.. That would be your cheapest option if you like your current ride height.
I wouldn't do coilovers unless you want ride height adjustments. Bilsteins are a great shock also. I ran Megan Racing coil overs.. I wanted the shock dampening feature as well as height adjustments
![]() ![]() ![]() Drives: MR2 Spyd/Type R/Yaris/Civic Si Join Date: Feb 2007
I've got a coilover setup on mine that would be about $2k in todays market if they were still available, which is admittedly a little bit on the expensive side (almost 1/5th the total price of my car when new)
However...... I love them for the almost infinite range of ride height adjustability and tuning capability
https://www.instagram.com/3cyltrbo/ |
i had megan coilovers on my liftback...they were FIRM for DD-ing on rough streets. were great on the track/auto-x though.
After racing for awhile, I have noticed many drivers who tune their suspension will mix and match setups by swapping different spring rates with different companies front and rear. Nothing beats a well designed shock though. Many racers love the Bilstiens for the customization and rebuild kits they offer. It depends on how much you like to "fine tune" a cars suspension
#10 | |
Data doesn't lie
I will likely do the same eventually, but for now I'll just be testing what BC sends me. I've gotta compensate for the weight reduction then dial in on spring rates accordingly
![]() ![]() Drives: 2008 Red Toyota Yaris Join Date: Mar 2011
It depends on what you are looking to improve on when doing any mod. Coilovers won't necessarily help you go faster in a straight line if that is what you are looking for, and as many of the others have said, it will cost more to get a proper setup with coilovers but it will also improve handling.
#12 | |
Post count means nothing.
Drives: AW11, NCP91, Old Motorcycles Join Date: Jul 2006
. Minimal improvement on an underpowered car like the Yaris but milliseconds count.
#13 | |
#14 |
![]() Drives: 2012 Yaris L 3 Door 5 S Join Date: Mar 2012
Installed KYB AJX, good range settings 1-5, keep it on 1 for daily driving, and won’t shake out your dentures.
#15 |
Been on my Megan Coilovers since 2011, absolutely love them (surprisingly). The F2's on my MR2...absolutely hate them...Will be switching the MR2 to AMR coilovers.
The stiffness/harshness of the ride will depend on the spring and the low speed damper valving in the shock. Tuning is limited on most coilovers I see for the Yaris but generally with my cars (and bikes) I match the springs to the weight of the car (or bike) and intended driving then, I adjust the damper accordingly (Megan's allow for some damper adjustment). With the Megans, the spring rates were good for my driving style and my uses so I didn't have to change anything around. The MR2's F2 coilovers (same as D2), the damper on those are rubbish and I played with many spring rates and damper settings and couldn't get the car to perform how I wanted. The dampers just didn't rebound the way I wanted and overall they felt mushy even with slightly stiffer springs (too stiff and you lose traction). But for just lowering and daily puttzing around, the F2's were good at that. |
#16 |
![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2013
I wanted coil overs in a way, but because I tow and carry weight sometimes, went with the stiffer (and taller) springs, the Mexican rough road from Yota. I also put the TRD struts n shocks, n changed the sway bar end links while apart.
Handles great and is everything I wanted and one thing I didn't want, high speed lift. Over 85 mph, the front took me a few months to get used to, as the raising of the center of gravity made it handle differently, and lift at higher speeds. I think I can counter this with a custom lower sitting front lip, but try and not hang out at the high speeds unless I have drift space. After driving a couple months, I seemed to have gotten used to the new way it handles, and if I didn't tow anything, would have just went with TRD lowering springs. Of course I wanted the dual adjustable coil overs, but couldn't justify the expense as I don't race it on a circuit, just A to B and the fun. Ideally, I would have just changed rear shocks and went with stiffer spring rates same height, but no one makes that unless custom, also higher dollar than wanted. In the end, because of towing or weight carrying, my mix is good for me and I am happy overall.
2010 Yaris sedan, TRD CAT back (sport muffler only, really), OBX header (relocated front AF sensor to front pipe), OBX throttle plate spacer, K&N filter (in stock air box-for now), TRD struts and shocks, Mexico Rough Road Springs x 4, new Yota sway bar links front, slotted/drilled rotors and Maxx brakes front, Valvoline synthetic brake fluid, 3M undercoated, 16" Konig Feathers Michelin Pilot Sport AS 3 + Tires TRD rear sway bar, 4 GT Spec bars including: front strut brace 2 point, 4 point ladder brace, mid chassis brace and rear lower tie brace, rear hitch, [B]
| need help on megan coilovers | chexmix | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 27 | 01-26-2016 04:13 AM |
| FT: Tein basic Coilovers SOCAL!!! | Mister Z | Items for Sale by private party | 0 | 03-27-2011 05:24 PM |
| Megan Coilovers $550 including install!!! | Walter | Items for Sale by private party | 14 | 09-29-2010 12:01 PM |
| FS: Tanabe Sustec Coilovers | thebarber | Items for Sale by private party | 6 | 07-16-2010 10:53 AM |
| FS: Megan Coilovers and Megan Axleback Exhaust | thebarber | Items for Sale by private party | 19 | 04-08-2010 04:06 PM |
