Old 05-03-2017, 06:43 AM   #1
rabbito
rabbito's Avatar
Drives: 2012 Toyota Yaris Sedan (Vios)
Give me opinion on coilovers
I have performance shock and struts, of course their not adjustable...they are stiff of course with 2" drop...
will coilovers be different than performance shocks strut other than adjusting heights and control soft - hard?
i was trying to purchase set of coilovers and some of the people i know said it should be almost no difference since you got performance shock and springs
Sent from my SM-N920C using Tapatalk
Brain: ATD E85 Timing Advance ECU
Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter
Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock
Electric: Volt Stablizer & Multi gauge obd2
Cosmetic: Toyota red emblem
rabbito is offline   Reply With Quote
Old 05-03-2017, 09:02 AM   #2
tmontague
tmontague's Avatar
I've only ran performance struts and could but from reading many forums of others whom have done both the consensus seems that a good quality set of struts and could will out perform a poor or mediocre set of coil overs.
Most people say if you want the adjustment then get co's but you need to pay to play. Usually above $1k is where you get the decent quality co's.
Armstrong was running to kill blues and micro image springs. He'll be running some BC co's Nina few weeks so watch out for his review as that will be a great compassion
Old 05-03-2017, 09:10 AM   #3
Originally Posted by tmontague View Post
go kill blues
Nice! Gotta love spell check.
Good spring/shock/strut combo all the way. Quality coilovers are way too expensive for what the average person requires.
Old 05-03-2017, 11:42 AM   #4
tmontague
tmontague's Avatar
My fat fingers hit every Damn key...
But I agree, $1200USD and up is a very steep price to pay unless you track your yaris and need it corner balanced/constantly need to adjust height and dampening
Tried and true bilstein b8's can be bought off eBay for less than $400 USD and there are a plethora of great lowering springs for our car
Old 05-03-2017, 03:30 PM   #5
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
Koni makes adjustable shocks.. That would be your cheapest option if you like your current ride height.
I wouldn't do coilovers unless you want ride height adjustments. Bilsteins are a great shock also.
I ran Megan Racing coil overs.. I wanted the shock dampening feature as well as height adjustments
-Derrick-
Old 05-04-2017, 10:12 PM   #6
3cyltrbo
I've got a coilover setup on mine that would be about $2k in todays market if they were still available, which is admittedly a little bit on the expensive side (almost 1/5th the total price of my car when new)
However......
I love them for the almost infinite range of ride height adjustability and tuning capability
3cyltrbo is offline   Reply With Quote
Old 05-05-2017, 09:21 AM   #7
i had megan coilovers on my liftback...they were FIRM for DD-ing on rough streets. were great on the track/auto-x though.
Old 05-06-2017, 01:30 AM   #8
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Allegedly there's a company called Stagg that offers Yaris shocks/struts, too.
http://staggshocks.com/Stagg%20AG/St...a%20Yaris.html
All four for $128?!?!? http://brandcarparts.com/2006-2012-t...-struts-4.html
$128! Wow! Seems too good to be true, but then again I have never heard of Stagg. Anybody here actually use these?
NYC-SE is online now   Reply With Quote
Old 05-06-2017, 02:15 AM   #9
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
I have a set that i'm planning on installing this summer with a set of Microimage springs.
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog
invader166 is offline   Reply With Quote
Old 05-06-2017, 04:02 AM   #10
NYC-SE
NYC-SE's Avatar
Cool. Interested in hearing how they perform.
Old 05-09-2017, 01:11 PM   #11
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
I loved the Tokico Blues and MI springs from the moment I installed them. I raced on them for 3 years and they are great, but now I'm on Rcomps and the body roll is getting insane.
I ordered a custom set of BC DR coilovers, it will take then 2-4 weeks to build them and they were well over $1000
Sent from my SM-G955U using Tapatalk
Old 05-09-2017, 08:14 PM   #12
ilikerice
ilikerice's Avatar
After racing for awhile, I have noticed many drivers who tune their suspension will mix and match setups by swapping different spring rates with different companies front and rear. Nothing beats a well designed shock though. Many racers love the Bilstiens for the customization and rebuild kits they offer. It depends on how much you like to "fine tune" a cars suspension
-Derrick-
Old 05-13-2017, 04:39 PM   #13
ArmstrongRacing
Data doesn't lie
I will likely do the same eventually, but for now I'll just be testing what BC sends me. I've gotta compensate for the weight reduction then dial in on spring rates accordingly
Old 06-16-2017, 12:17 AM   #14
alias06
Drives: 2008 Red Toyota Yaris
It depends on what you are looking to improve on when doing any mod. Coilovers won't necessarily help you go faster in a straight line if that is what you are looking for, and as many of the others have said, it will cost more to get a proper setup with coilovers but it will also improve handling.
alias06 is offline   Reply With Quote
Old 06-16-2017, 12:33 PM   #15
heeroyuy01195
Post count means nothing.
Drives: AW11, NCP91, Old Motorcycles
Been on my Megan Coilovers since 2011, absolutely love them (surprisingly). The F2's on my MR2...absolutely hate them...Will be switching the MR2 to AMR coilovers.
The stiffness/harshness of the ride will depend on the spring and the low speed damper valving in the shock. Tuning is limited on most coilovers I see for the Yaris but generally with my cars (and bikes) I match the springs to the weight of the car (or bike) and intended driving then, I adjust the damper accordingly (Megan's allow for some damper adjustment). With the Megans, the spring rates were good for my driving style and my uses so I didn't have to change anything around.
The MR2's F2 coilovers (same as D2), the damper on those are rubbish and I played with many spring rates and damper settings and couldn't get the car to perform how I wanted. The dampers just didn't rebound the way I wanted and overall they felt mushy even with slightly stiffer springs (too stiff and you lose traction). But for just lowering and daily puttzing around, the F2's were good at that.
heeroyuy01195 is offline   Reply With Quote
Old 06-16-2017, 12:36 PM   #16
heeroyuy01195
Coilovers can help with straight line drag racing. Depending on how they're setup, you can improve your traction on launch and reduce "bob" while shifting gears which keeps the wheels planted so more power to the pavement. Minimal improvement on an underpowered car like the Yaris but milliseconds count.
Old 06-19-2017, 12:01 AM   #17
alias06
Yes a well set-up suspension can help anywhere, but switching from a good spring/strut combo to an off-the-shelf setup isn't going to make a huge difference.
Old 06-27-2017, 07:51 PM   #18
ccyaris
Drives: 2012 Yaris L 3 Door 5 S
Installed KYB AJX, good range settings 1-5, keep it on 1 for daily driving, and won’t shake out your dentures.
ccyaris is offline   Reply With Quote
need help on megan coilovers chexmix Wheels, Tires and Suspension Forum sponsored by The Tire Rack 27 01-26-2016 04:13 AM
FT: Tein basic Coilovers SOCAL!!! Mister Z Items for Sale by private party 0 03-27-2011 05:24 PM
Megan Coilovers $550 including install!!! Walter Items for Sale by private party 14 09-29-2010 12:01 PM
FS: Tanabe Sustec Coilovers thebarber Items for Sale by private party 6 07-16-2010 10:53 AM
FS: Megan Coilovers and Megan Axleback Exhaust thebarber Items for Sale by private party 19 04-08-2010 04:06 PM
