Old 05-21-2007, 03:55 PM   #1
DoriKnights
Drives: Rps13
20v vvti
ok yaris heads... so i recently posted a thread on 2zzge, my search continues for a motor that puts out more power that wont *uck me financially.. some one mentioned then 20v 4age it is off of a levin and is FF and so i think this will be a more convinient swap , its awsome OEM ITB'S .. i need input out there sure its older but, its off an ff platform and just a lil bigger.. 1.6, the engine is fairly cheap, to those hardcore enthusiests out there, know of any one who has done it..? what major fabs will i be looking at..? how different are the tranny's and the mounts, i will be doing research as well.. but the comunity will probably help a lot more than some sites..
DoriKnights is offline   Reply With Quote
Old 05-21-2007, 04:23 PM   #2
cdydjded
Drives: Yaris LB Turbo
DoriKnights;88330]ok yaris heads... so i recently posted a thread on 2zzge, my search continues for a motor that puts out more power that wont *uck me financially..
1st problem, if you are not willing to spend $$ you are not going to get more power.
2nd problem "convinient swap" that is an oximoron. No one has swaped anything into our cars so there is nothing convinient about it
No one has done a swap
what major fabs will i be looking at..? how different are the tranny's and the mounts, i will be doing research as well.. but the comunity will probably help a lot more than some sites..:thumbsup
No one can answer this question. All you are going to get is guessing and speculation.
Old 05-21-2007, 04:37 PM   #3
weaponrcamry
Drives: Camry LE/Yaris Hatch 5spd
Yes, I remember that post a while back. I am the one that posted about the 4age 20 valve black top. The pictures I posted a while back are from overseas somewhere. What I heard a while back is that the company that did the swaps got shut down some how. Not because of the swaps something else, maybe they didn't get enough business. But here is what you should check first before you do this, unless you are towing the car on the back of a trailer and you won't be driving it on the street.
For example I will use California because it seems to be the strictest.
California lets you to swap engines into you vehicle, as long the the engine is the same year or newer than the chassis with all of the wiring that works.
What this means is that the blacktop is a motor that was used in the 1990-1999 I think??
Know the only motor that was produced newer or the same year as the yaris(U.S. spec). You only options are the 1zzfe, 2zz-ge, rebuild the 1nz-fe, or the new dual vvti (2RZ-FE the new xd/corolla) These are the motors that I know will fit in the chassis, and will pass the emissions visual check when that time comes. Check you emissions law if you have one, if you don't, I would do the 20valve black top. Good luck. :)
|.....Overnight.........................| ||
|........Parts From Japan.............||'|";,__
|_..._...____________======||_|_|....,,]
weaponrcamry is offline   Reply With Quote
Old 05-21-2007, 05:30 PM   #4
cdydjded
How are you going to get by the electronic throttle body?
Old 05-21-2007, 07:01 PM   #5
DoriKnights
Drives: Rps13
http://cgi.ebay.com/ebaymotors/JDM-4...16508226QQrdZ1
Old 05-21-2007, 10:48 PM   #6
weaponrcamry
Ok here is a little list that I came up for the swap.
1. Engine $900
2. 5 speed Tranny $200
3. Master Ecu?
4. Clutch Pedals?
5. Shift Linkage?
6. Shift boot?
7. Clutch Resvoir?
8. Axles?
9. Hubs?
10. Brakes?
11. Shift bushings?
12. Custom Suspension?
13. Knuckles?
14.Custom downpipe?
15. Custom intake?
16. WIRING?
17. Power steering?
18. Man HOURS!!!!
19. Custom Drive Shaft
20.$$$$$$$$$$$$$$$$$$
21. More Man Hours.... Whooo HAhaha.
You can probably get a way with spending about 10k if you do it yourself, get junkyard parts. But 15k for sure. Their are no resources, that we know of. What you really should do is get a hold of Street Image. They have did the swap before. http://www.streetimage.com/#
I posted this a while back to on the forums.
http://www.yarisworld.com/forums/sho...&highlight=2zz
Oh yea, while reading, it says about the 2zz-fe. Their is no such thing. I am 1000% sure you cannot use a fe head, on the the 2zz-ge motor, they are totally different, and it wouldn't just work. To be honest I would do either the 2zz-ge swap, or just boost the 1nz-fe motor. Their are after-market parts available for both engines. Until then be--------->
Please trust me on this one...
Engine Changes
Engine changes are legal as long as the following requirements are met to ensure that the change does not increase pollution from the vehicle:
* The engine must be the same year or newer than the vehicle.
* The engine must be from the same type of vehicle (passenger car, light-duty truck, heavy-duty truck, etc.) based on gross vehicle weight.
* All emissions control equipment must remain on the installed engine.
I will email them myself 2 morrow, and ask them what was actually involved with the swap.
Old 05-21-2007, 10:16 PM   #7
ChinoCharles
Drives: LB
IMHO, the 4A-GE 20v motor swap is the pinnacle of Yaris modding. I would pay good money to see it happen one day, but I'm not holding my breath.
A quick crash course c/o Wikipedia...
4A-GE (20-valve)
black-top 20 Valve 4A-GELU Engine(Japanese-spec) in 1996 Carina GTA special 4A-GE was produced from 1991 through 1998 to replace the 16 valve 4A-GE. It was a naturally-aspirated engine with an additional intake valve for each cylinder, making it one of the first production 5-valve engines in history. These generation engines also featured quad throttle bodies. The engine can be recognized by its silver or black top. This was the last of the 4A family to be produced. Toyota VVT was used for 160–165 hp (123–127 kW) at 7800 rpm and 120 ft·lbf (162 N·m) at 5600 rpm, quite impressive for a naturally-aspirated 1.6 L engine. Note that although VVT was present in the silver top and the black top 4A-GE, VVT-i was not available.
Some Racing team participating in the Group A of the JGTC, using either the AE101, AE86 or AE82 corollas. These cars used modified silvertop versions of the engine, capable of approximately 240 Horsepower at 11,000 RPM.[citation needed]
Applications:
1992 Toyota Corolla Levin, Sprinter Trueno AE101 (silver-top) All GT models (GT Apex GT-V etc)
1995 Toyota Corolla Levin, Sprinter Trueno AE111 (black-top) All BZ models (BZG, BZR, BZV etc)
Old 05-22-2007, 06:07 AM   #8
GuySmily
GuySmily's Avatar
Drives: 2005 Toyota MR2
This is a popular swap among us 1st gen MR2 guys. Then again, we already have 4age's in our cars..
At least for the Yaris the manual tranny is in the same family (c-series). You may not need to buy a new one.
Here's one example:
http://www.padandwheels.com/mr2/blac.../blacktop.html
GuySmily is offline   Reply With Quote
Old 05-22-2007, 03:24 PM   #9
DoriKnights
Drives: Rps13
Here's one example:
just found out @ scionlife.com that the tranny may just bolt right on.. .... since they have pretty much the same layout.. well the xa.. .. hmm more research...
Old 05-22-2007, 05:31 PM   #10
YarisGuy
Drives: 2006 Yaris
Very interesting! Look to see if you can find part numbers on the clutch and flywheel for the Yaris and MR2. If they match, you are one step closer.
It's a red yaris
YarisGuy is offline   Reply With Quote
Old 05-22-2007, 06:37 PM   #11
weaponrcamry
yes, we have discovered that the tranny from the 4age bolts right up to the yaris 1nz-fe if that's what you are talking about?? Maybe vice versa to. It wouldn't make since to put the yaris tranny onto the 4age because it is weaker IMO.. Just get the whole tranny that comes with the 4age(STRONGER). If you do this project please write a write up. The seems very interesting. I also here that the 2zz-fe tranny bolts up to the 1nz-fe also.
How much power do you want??? You can get about 220-230whp on the stock motor/tranny until you have to rebuild or so. The stock crank is good for around 9,000-9,500rpm.
Why don't you get this motor. http://cgi.ebay.com/ebaymotors/4AGE-...QQcmdZViewItem It has all the things that you need.
It would be better to get a whole front clip, but o well. The most difficult part of the swap is the wiring. Have fun...
Old 05-22-2007, 07:13 PM   #12
RobStar86
Drives: 2013 Toyota Yaris LE Hatchback
The hardest part I can see about this swap is making sure you can get the axles and mounts and such to work. The wiring would be the easiest bit assuming you go with a stand-alone like megasquirt or something like that.
If you want just N/A power, go blacktop. If you want to go for boost later on, go with a silvertop, they are better suited to turbo.
Oh yeah, first post! Hi Everyone!
RobStar86 is offline   Reply With Quote
Old 05-22-2007, 07:56 PM   #13
DoriKnights
Drives: Rps13
so far there are others in the scion comunity attempting the same swap.... check it out
"according to some reading, the C50 and C160 transmissions fit it thus the xB and xA's C150 will fit just fine. just seems to be an obviouse swap option and looks to be more on the simple side compared to other options
Old 05-22-2007, 08:02 PM   #14
DoriKnights
Drives: Rps13
http://www.scionlife.com/forums/viewtopic.php?t=176180
check it..
Old 05-22-2007, 11:42 PM   #15
YarisGuy
Drives: 2006 Yaris
This thread is getting very interesting!
It's a red yaris
Old 05-23-2007, 11:29 AM   #16
KS SOLO
Drives: too many 2 list
It would seem a lot of work to get 160hp?, when you can just add a turbo now and get the same results, much cleaner, less custom, or am I missing something? Or this just one of those projects done for the pushing the envelope?
KS SOLO is offline   Reply With Quote
Old 05-23-2007, 11:46 PM   #17
RobStar86
Silvertop does not come equipped with TVIS. TVIS was on the earlier 4age 16v. Both the silvertop and blacktop run ITB's. Although i'm pretty sure the blacktop uses a map sensored system which allows you to run the ITB's open without an intake plenum. Silvertop does not.
I own a couple corollas and I was considering swapping the 20v, but if I pick up a yaris, I might as well just swap it in that.
If you check this link:
http://www.club4ag.com/faq%20and%20t...ifications.htm
Check the stats between the ae101 (silvertop) and ae111 (blacktop). You can see the blacktop is just more set up to rev.
Old 05-24-2007, 12:55 PM   #18
DoriKnights
Drives: Rps13
ok i never have done so much damn research in my life! but this swap would be hella worth it.. at least i would think so, sure turbo is the easy way to more power but this engine simply is beautiful, that power NA with still more potential to go
HERE ARE SOME PICS OF A BLACK TOPS ENGINE BAY
http://www.japparts.com.au/images/20vblk.jpg
AND YARIS ENGINE BAY, SOMETHING U HAVE NEVER SEEN BEFORE .. JK
http://images.motortrend.com/oftheye...ngine_view.jpg
VVTi Managment Greddy Black Yaris Performance Modifications 29 08-12-2007 08:29 PM
4age 20v powered Yaris slothman86 General Yaris / Vitz Discussion 3 04-04-2007 08:31 AM
