Old 06-15-2017, 08:07 AM   #1
signOrama
Drives: TOYOTA YARIS SEDAN 2017
DIY-Installing Fog Lamp for 2017 Yaris Sedan
hello guys..does anyone here has a manual, tutorial for installing a front fog lamp for 2017 Yaris Sedan- Dual VVT-i (automatic)..i just want to learn a lot for my car...thanks in advance..more power to this site-YARISWORLD..
signOrama is offline   Reply With Quote
Old 06-15-2017, 02:11 PM   #2
vivalaflam
Enthusiast
vivalaflam's Avatar
Drives: 07 Yaris HB 1.3 (EU)
Congrats on your new car! Please go introduce yourself in the corresponding thread first, post some pics of your ride, and welcome to the yarisworld forum! Enjoy your stay:)
Cheers, George.
vivalaflam is offline   Reply With Quote
Old 06-20-2017, 09:32 PM   #3
ccyaris
Drives: 2012 Yaris L 3 Door 5 S
I don't think there is an easy DIY doc available, you will have to piece together ideas from several threads. You have 2 options, both require some technical knowledge, or access to a mechanic.
The first option, remove the wheel liners and install Fogs behind the bumper, the power supply harness is taped nearby, just connect to fogs. Next, if your headlight stalk has fog switch on it you are done. Otherwise you will have to splice in a fog switch as done in several posts.
Second option which I did, once fogs are connected, you will have to remove the steering wheel and R/R the stalk with one with fogs ( I used Subaru BRZ, stalk cheaper than SCION). You may have to reset steering air-bag.
ccyaris is offline   Reply With Quote
2012 Nissan Versa Kal-El Off-topic / Other Cars / Everything else Discussions 22 06-15-2012 04:48 PM
yaris Advance Sedan Rudeshady Central and South America 14 06-25-2007 01:50 AM
