Old 06-17-2017, 02:57 AM   #1
yariseggvvti
Drives: Yaris Hatchieback
Rear SE axle beam swap
Have any one done a Yaris SE rear axle beam swap? If you had done one, please give a list of parts I need. Post some pictures please.
Thx!
yariseggvvti is offline   Reply With Quote
Old 06-17-2017, 08:56 PM   #2
heeroyuy01195
Post count means nothing.
Subscribed...
Old 06-17-2017, 09:13 PM   #3
enviri
enviri's Avatar
Drives: 2010 Yaris
what, swapping JUST the beam? Most of the swaps are complete off a junker...give or take the 2 ebrake cables.
you can get more info on swapping off this theory thread. my post #5 isnt much a theory, more of a laundry list of what the rear disc setup is made out of.
http://www.yarisworld.com/forums/sho...rear+disc+swap
Old 06-19-2017, 11:18 PM   #4
yariseggvvti
complete rear axle beam swap. I looking for it from junk yard now and its hard to find one. What additional parts beside complete axle beam assy i need?
Old 06-19-2017, 11:33 PM   #5
enviri
enviri's Avatar
Drives: 2010 Yaris
nothing, really. you might prefer a more front bias again and get an SE brake booster and proportioning valve, but really isn't needed. (i seem to forget if there's something else under the hood related to that booster area)
setup as is, the swap will make your rear brake pad last as long as your fronts.
Old 06-20-2017, 03:42 AM   #6
yariseggvvti
Thanks for the advise.
Old 09-23-2017, 01:44 PM   #7
DarkShadowFox
pads are like what 26 a piece if you go non oem.
Sent from my LG-H918 using Tapatalk
Old 06-20-2017, 10:58 AM   #8
enviri
enviri's Avatar
Drives: 2010 Yaris
just fyi your rear brakes will be larger than your fronts after the swap lol.
Old 06-21-2017, 12:38 AM   #9
SirDigby
Drives: 2007 yaris 3 door
you can do a corolla front brake swap to balance it out...
Old 06-21-2017, 02:31 AM   #10
yariseggvvti
na..that's too much. the reason getting rear disc brake cuz it has drum there.
this will be the last mod of my ten years yaris.
Old 06-21-2017, 02:17 PM   #11
Better question would be why do you need rear disc brakes compared to drum brakes?
Old 06-21-2017, 02:33 PM   #12
Because, when glimpsed between the spokes, a disc with painted caliper looks cooler than a rusty drum?
Old 06-21-2017, 07:16 PM   #13
Ah, true. Only if it weren't so costly.
Old 06-21-2017, 05:25 PM   #14
kimona
kimona's Avatar
Drives: 2014 White VITZ
Good point. For everyday driving, the OEM disc/drum brake set-up works very well on this little car.
But, like WeeYari stated, maybe it "looks cooler" with disc brakes on the rear.
Old 06-22-2017, 03:23 AM   #15
yariseggvvti
adding little bit more weight and get more stopping power.
Old 09-23-2017, 01:43 PM   #16
DarkShadowFox
ease of mainentence and suchs. have you ever seen a drum brake its a pain in the butt to get new shoes on and their is four of them. not just one or two pads like on a disc break caliper.
Old 06-21-2017, 08:34 AM   #17
enviri
enviri's Avatar
Drives: 2010 Yaris
i dont know about being too much..at least think about running the bigger disks + SE front calipers later.
Old 06-21-2017, 08:14 PM   #18
tmontague
tmontague's Avatar
Imo if Jason, Tom others can track/race their Yaris' on stock drums, then there's no reason for rear discs other than looks
rear beam question: one wheels sticks out more DINOeggxo Wheels, Tires and Suspension Forum sponsored by The Tire Rack 58 05-10-2014 10:38 PM
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 05:02 PM
