Old 08-04-2017, 02:21 PM   #1
scylla
Drives: 2015 Yaris L
Cruise control 2015
OK I am getting ready to do a cruise control install using whatever switch has the best reviews from Amazon or Rock Auto. It seems there are quite a few.
I will be using instructions outlined here...
http://www.paulstravelpictures.com/2...ide/index.html
But looking at the drilled hole in the access plate for the switch has my OCD kicked into high gear. Looks really sloppy.
Anyone got a neater way to do this? Maybe a rubber grommet?
scylla is offline   Reply With Quote
Old 08-04-2017, 06:16 PM   #2
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Looks like it gives the same part number for the cruise control switch. See this thread http://www.yarisworld.com/forums/new...ote=1&p=801287 for Yaris specific info.
Once it is installed, you won't see the hole. I put some foam mesh from a computer cooling fan filter over the switch behind the cover plate to prevent dust entry. I believe the correct cover plate is available for a reasonable price from Toyota.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 08-04-2017, 06:21 PM   #3
scylla
Thanks for the quick answer, but the link you shared is for thread reply.
Old 08-04-2017, 07:08 PM   #4
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Sorry, my error. should be http://www.yarisworld.com/forums/sho...cruise+control
Old 08-06-2017, 10:16 AM   #5
laobo
Drives: yaris sedan 2011
Dear friends.
How to tell me the way connected from ECM to cruise control swich? .application for yaris sedan 2014..
laobo is offline   Reply With Quote
Yaris 2015 Cruise Control & ASL Gagi Third Gen Yaris General Discussion 27 10-05-2022 04:03 PM
Adding cruise control to 2015 model? hayden DIY / Maintenance / Service 2 08-16-2015 06:43 PM
