Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Marketplace > Willing to Buy by private party
Old 12-30-2018, 10:44 AM   #1
Tskm2
Drives: Yaris hatchback 06
Penguin garage axle spacer
Search for a set or someone with draw of all measure to made one. Fors 06-07yaris
Tskm2 is offline   Reply With Quote
Old 12-30-2018, 11:56 AM   #2
tmontague
tmontague's Avatar
If you can wait until the spring I will he selling my 10mm penguin spacers with camber washers.
I'm going to a wider 225 track tire and that wont fit with the 10mm spacers
Old 12-31-2018, 08:30 AM   #3
Leegamer
Leegamer's Avatar
Are you just looking for slip-on spacers? If so there are a billion companies that sell them.
I'm a hermit named Lee
Old 12-31-2018, 06:09 PM   #4
Tskm2
Pm's tmontague
I run wheel spacer on all my car/truck. But couple years ago a made a set of axle spacer for my jetta mk2 and it so much better and on wheel bearing too
Old 01-03-2019, 11:12 PM   #5
enviri
enviri's Avatar
Drives: 2010 Yaris
found mine :P these are way too tight to fit hubs with abs. it really sucked removing these from my hub.
Old 01-17-2019, 03:59 PM   #6
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Interesting. Mine weren't a bad install at all. Getting the hub off before the spacer install was tough, but putting it all back together was a breeze, but I did have the mechanical advantage of the bolts. However, removal, that may be a different story.
Now you've got me wondering...does my '06 have ABS? Haha. The install was a while ago.
Old 01-17-2019, 10:46 PM   #7
enviri
enviri's Avatar
Drives: 2010 Yaris
go slam your brakes and report back lol
Old 01-18-2019, 05:57 AM   #8
06YarisRS
- a valid test for sure. However, since it's still up on stands with the front torn off, I'll look for the sensors. LOL.
Old 01-18-2019, 11:45 AM   #9
myfirstyota
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped
I've had to use a slide hammer every time to get the rear hubs out.
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61427
Bolt-in 3.75" Suspension Lift Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61577
myfirstyota is offline   Reply With Quote
Old 01-17-2019, 10:57 AM   #10
myfirstyota
If any Canadians are looking for a more local sale of their spacers, I'd be interested
Old 01-18-2019, 12:08 PM   #11
tmontague
tmontague's Avatar
I opted for the air chisel when I had to remove them to install the spacers. Now I never have any issues since everything is covered in anti seize. If only the factory would do the same...
Old 03-20-2019, 07:13 PM   #12
Tskm2
In search again!
Old 03-20-2019, 07:15 PM   #13
Tskm2
Or someone he's able tho draw/template exactly on sheet and mail for a made custom one. I dont have old/scrap bearing to take measure
Old 03-24-2019, 06:35 PM   #14
enviri
enviri's Avatar
Drives: 2010 Yaris
https://imgur.com/a/eotSAt7 on regular 8 1/2 x 11 :P
Old 03-28-2019, 08:47 AM   #15
Tskm2
Alrigth thank! I print it and try the template!
Old 03-28-2019, 12:35 PM   #16
06YarisRS
I think this will make many people happy!
TRD Delrin Rear Axle Bushing Collars tmontague Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 12-15-2019 07:50 PM
WTB Penguin Garage Hub Spacer Hoang2zz Willing to Buy by private party 0 06-25-2018 02:25 PM
New Product: Penguin Garage Rear Camber Shims! Penguin Garage Penguin Garage 11 10-22-2009 10:20 PM
Penguin Garage Rear Hub Spacers!! Penguin Garage Sponsors Classifieds Area 92 09-02-2009 06:16 PM
Penguin Garage Rear Hub Spacer Raffle!! Penguin Garage General Yaris / Vitz Discussion 27 06-30-2009 01:05 AM
