Old 03-16-2019, 04:01 AM   #1
SLIFox
Drives: 2008 Manual YRS Sedan
08 Yaris Manual Sedan Running Poorly
Hey Everyone,
Just today, after an inspection on the car, I came across oil in my PCV and surrounding hoses. In addition, my coolant has become a murky brown colour when the coolant was red when I last checked it 2 months ago. Upon further inspection my oil when viewed on the dipstick was dark brown and smelt like burnt oil.
All this after only 5000kms and 8 months running time on the oil.
Furthermore, there is a significant decrease in overall performance and power which I'm not sure of the cause.
One last thing I should add, was when driving back from shopping a few days ago, I noticed a minor, intermittent ticking noise coming from the engine.
If anyone can help me and give me some advice on what it could be, that would be fantastic.
Thanks in advance,
SLIFox
SLIFox is offline   Reply With Quote
Old 03-16-2019, 06:54 AM   #2
2bz
Drives: 2008 Yaris 3DR Hatch MT
Oil/coolant interaction. Did you have an overheating event? I'm going to go with number 1 below.
Blown head gasket
Defective or deteriorated seals
Improperly torqued head bolts
Thermally warped or cracked cylinder heads
Cracked block or cylinder head from frozen coolant
Improperly machined head and block surfaces
Corrosion damage of cylinder liners
Damage or corroded cooler cores
Water pump seal failure and weep-hole blockage
2bz is offline   Reply With Quote
Old 03-16-2019, 08:09 AM   #3
SLIFox
Blown head gasket
No never overheated in it's life, it was my first manual car and did have a rough start when I was learning.
I have only done 6000km since I got it with 227000km on the clock now.
Probably never had valve seals or anything checked.
What are the main things that can go first and foremost? Valves sealing be an issue?
Sent from my SM-G965F using Tapatalk
Old 03-16-2019, 10:03 AM   #4
tmontague
tmontague's Avatar
If you purchased the car with 227k km on the clock then how are you so sure it has never overheated in its life? I would be suspect of some serious engine issues from its previous owner that just took a few thousand kms to show up since you took ownership
Old 03-16-2019, 10:09 AM   #5
SLIFox
I can be sure as it was my boss's car and I had a previous history with her prior to purchase, nothing out of the ordinary except for a battery drain issue this has all started since doing city and interstate driving.
Old 03-16-2019, 10:02 AM   #6
tmontague
tmontague's Avatar
All of the above as well as a blocked pcv valve. Remove the pcv valve and clean it out from both side with some brake cleaner or other solvent. Re install and change the oil and see if the problem persists
Old 03-16-2019, 01:55 PM   #7
2bz
Shit! Why didn't I think of that?
Check for these codes:
P051F: Positive Crankcase Ventilation Filter Restriction
P053A: Positive Crankcase Ventilation Heater Control Circuit /Open
P053C: Positive Crankcase Ventilation Heater Control Circuit High
Old 03-16-2019, 10:35 AM   #8
dogsridewith
Drives: 2007 2-door hatchback
Maybe the battery drained and the head/block warped when the serpentine belt failed, the alternator and water pump stopped turning, and the driver kept driving.
Old 03-16-2019, 08:58 PM   #9
dogsridewith
How would the coolant darkening relate to a blocked PCV valve?
I had a small block Chevy metal PCV valve clicking so loudly that I adjusted the valves on that side before discovering what it was. It wasn't dirty, and the same looking (and same acting, in hand) replacement PCV valve was quiet.
Old 03-16-2019, 09:54 PM   #10
tmontague
tmontague's Avatar
Excess crankcase pressure can do strange things.
It may not necessarily be causing the coolant issue but it is the simplest thing to check and rule out so it should be done first
Old 03-17-2019, 07:14 AM   #11
2bz
Over pressure damage to head/other gaskets allowing oil and or combustion gasses to mingle with coolant.
Old 03-17-2019, 01:50 PM   #12
dogsridewith
Yes. First thought was that the head gasket has to withstand combustion pressures, so it wouldn't feel the elevated crankcase pressure from a plugged PCV valve. But the HG has metal rings that are only holding combustion pressure...and maybe a small metal or other special detail around the oil supply port.
Old 09-15-2019, 02:29 AM   #13
rayfloyd170
Drives: Yaris 2016 1.3 Manual
any update on this and hope we can learn something out of the experience
rayfloyd170 is offline   Reply With Quote
brown coolant, burnt oil, decreased performance, engine noise
Does anybody have the 2011 TMMF Yaris owner's manual? alexei General Yaris / Vitz Discussion 2 09-05-2013 04:20 PM
FS For Sale Toyota TRD Exhaust Yaris Sedan lll3 Items for Sale by private party 6 04-18-2013 03:07 PM
Yaris Sedan Vs. Yaris 4dr. hatch Meow General Yaris / Vitz Discussion 11 10-29-2006 02:11 PM
