![]() Drives: 2015 Yaris L Join Date: May 2006
Minor Annoyance: Driver Door Panel Switch Cover
Hi,
Not sure if this is just me or occurs in other 2015 Yaris. The driver door panel switch cover is very creaky. Whenever I close the door from the inside by pulling the handle the plastic is very creaky there. I wonder if this is common? Also, when the fan is on, it makes a bit of a high-pitch sound. Is this normal? Thanks! |
![]() ![]() Drives: 2015 Yaris L Join Date: Jun 2017
I have same year, same model and I have neither of those problems. You can take the door panel off and see if you have a loose screw or mounting clip.
The whining fan would seem to be a bigger concern. Mine is super quiet. Open your glove box and make sure the fan is mounted securely and the blades don't wobble. |
Thanks, will check on it this weekend!
#4 | |
![]() ![]() ![]() Drives: 2017 Yaris L (5sp manual) Join Date: Jun 2012
Thanks for letting me know that I am not the only one that has a creaky door handle. I did pop off the plastic panel and tightened the screws around. I still have the same creak..haha..oh well
![]() ![]() Drives: 2018 Yaris LE liftback, 2020 Join Date: Sep 2018
I got the recall done for the front door wiring harness, and seems like the squeaking went away. My 2016
that's good to know..just waiting for my recall letter and hopefully that will fix the issue.
Maybe saw something loose and fixed it?
| Cruise control install 2009 Yaris 3 door | PeteZNY | DIY / Maintenance / Service | 125 | 03-31-2024 09:22 AM |
| DIY (08' USDM LB): Interior Light Color Change | revnull | DIY / Maintenance / Service | 37 | 05-21-2016 12:59 PM |
| WTB: Driver side view mirror cover | black06spec-v | Willing to Buy by private party | 1 | 09-16-2014 12:38 AM |
| LB Driver Side Mirror Cover (Backplate) | posaunemeister | Willing to Buy by private party | 2 | 10-17-2011 12:06 AM |
| TRD gauge cover for the driver glovebox | MicroHB | Willing to Buy by private party | 1 | 02-14-2009 12:37 PM |
