![]() Drives: 2015 Toyota Yaris MT Join Date: Aug 2021
eBay Spoilers?
Anyone have any experience with unpainted ABS plastic eBay spoilers? I'm getting my hatch door professionally painted and thought I might as well buy a spoiler and throw that on as well.
Will the painters be able to take the spoiler and paint it straight away or will there be significant prep work required? Here's some photos of the one I might buy. Described as "ABS Blow mold plastic material": ![]() ![]()
Gen 3 > Gen 2
Drives: NCP131, F-150, Focus ZTS Join Date: Jul 2019
The OEM spoilers are also ABS plastic, I got mine from the dealership, pre-painted. Took 20 minutes to install.
They'll probably have to prep it, it looks unprepped to me, but I may be wrong.
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2002 Ford Focus ZTS 5 speed 2013 Rav4 LE AWD Autotragic - Wife's
Gen 3 > Gen 2
the abs one i had purchased cracked down the middle within a year(hard winters and such)
i would highly advise the urethane factory ones. even if its not prepainted the material will hold up much better. now that you can get 2k auto paint in a aerosol you could even paint it yourself. |
im STILL in the middle of doing an ebay spoiler, got it for my wife in nov as an xmas present......it had issues out of the box, then presented more issue, and more...and more...ABS is a huge PITA..its either "ok or bad" between paint prep and chemical vs abs issues, it can either go quick n easy or just be a nightmare, im just finnaly getting to lay clear on it right now im in between coats
the big issue is abs is a "dirty" plastic and overseas companys tend to just make it out of the filthyest abs possible, top tip, coat it with several layers of high quality epoxy primer to seal it before working with it, the next big issue is that they are static monsters and will find and pull anything out of the air they can into the paint, lastly your normal "prep" chemicals wcan and likely will cause the plastic under the paint to wrinkle and do all sorts of fun stuff just as your about to finish painting..for some reason durring primer they wont show a hint of issue till the actual paint hits |
![]() ![]() Drives: 07 AT & 08 MT Yaris HB 3dr Join Date: Nov 2021
I bought mine off of eBay but it is the "S-Type" version. When you buy from this seller you provide your paint code and it comes pre-painted. I haven't installed yet, but I am going to soon. The finish looked great and came with everything needed. I'll post pics once the install is done.
https://www.ebay.com/itm/362949655191 Thomas |
#8 | |
..i HAVE that unit and had to take a heatgun to it and re-paint it just to make it fit...it was hitting the body, also for the love of god dont bolt it on with sheetmetal screws, instead drill a hole, and go thru the rear washer plug to put a fender washer and nut on it, drill a matching hole on the other side and do the same |
#9 | |
#10 | |
as far as the work i had to put in...the highs n lows were BAD....real bad, and initialy i thought that was the only issues so i went about doing the body work only to run into the OE primer wrinkling which ment i had to re-strip it, then i ran into "dirty plastic" which can be common on ABS and you basicly have to fight to get a good epoxy primer down clean of course once i sorted out the body work and the paint down..i found the side wings? were contacting the body..i could have shimmed n spaced it but it would have ment a gap under it and it wouldnt have "cupped" over the hatch meaning the leverage on the bolts would have gotten MUCH worse, so out came the heat gun and i pulled n tweaked the wingletts outward till it fit the way it should have, then went back to fighting to get a stable epoxy coat that wasnt wrinkling on the dirty abs plastic....i lost count of the hours i put into it, but can state that NO ONE should have to put that kind of time into it.....i coulda made one out of CF in less time....from scratch ![]() ![]() ![]() ![]() ![]() ![]()
i would be careful of that one as well. i had the same model years ago and the plastic split right now the middle. spending more and buying a urethane factory model is a safer bet. the ABS can be sketchy.
it was a gift for my wife for xmas..so....i basicly backed myself into a corner as soon as i got it..i DID get a full refund on it so all i had into it was time and supplys..but im also a stuborn bastage who likes a challange..and i dont like to lose a fight...so i eventualy won
i dont forsee it splitting as the material thickness is pretty good and since i had it down to absolute bare plastic i know its an injection blown unit ie only 1 seam and thats the low flat pad that took the most filler but agreed youve got to either have the time and skill or be 110% sure your getting something of quality the unit i wanted..i couldnt find IE the canadian RS version which has the sharper edges and the long "fingers" that extend out onto the hatch...given the chance ill swap it out for that...wife didnt notice the differance so im not about to point it out till i find one.... she wanted the RS soooooo bad but couldnt get over the 6month wait |
| Ebay "Superchargers" Rant | invader166 | Forced Induction Forum | 0 | 01-16-2016 07:12 PM |
| My Yaris (I should be sponsored by eBay) | D&D | Photo-Video-Media Gallery | 8 | 09-13-2013 04:35 PM |
| eBay Issue - Your help needed | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 6 | 02-04-2011 09:18 PM |
| WTB: Gauge Cluster w/tach for HB | cdydjded | Willing to Buy by private party | 12 | 06-09-2010 03:49 PM |
| Pre Hack Revival: Megan Racing Header vs Ebay Header | Sabretooth | Performance Modifications | 15 | 08-19-2009 05:26 PM |
