Originally Posted by sh0rtlife
BE WARNED
..i HAVE that unit and had to take a heatgun to it and re-paint it just to make it fit...it was hitting the body, also for the love of god dont bolt it on with sheetmetal screws, instead drill a hole, and go thru the rear washer plug to put a fender washer and nut on it, drill a matching hole on the other side and do the same
Thanks for the heads up. That's odd because I already did a test fit and mine fit perfectly. Also I'm going to use my step drill bit for the holes and attach it with threaded rivots/screws. You have any pics of the work or problems you ran into with the install? Thanks again.
