unknown sensor
found a sensor behind the bumper, left front just inside the plastic air chanel guards in front of the radiator below the crash bar.....anyone know what it is for?
if only found the sensor on AC equiped cars wondering if its a radiant sensor for the condensor temp? or an outside air temp sensor?...the car has the plug for it and i grabbed the sensor off an ac car and added it..just trying to figure out exactly what i added |
![]() ![]() ![]() Drives: 2007 Yaris Sedan Join Date: Apr 2009
Manual shows an Ambient Temperature Sensor.
In the area you are pointing out. In the Air Conditioner section of the manual. |
hmmmmmm i kinda wondered, now is that for displaying temp or for the ac system to compensate
Electrical diagram show it connected to the AC controller.
Since the AC controller also uses the CAN Buss to communicate with the car electronics. It may also be used to display a temperature. |
| trying to find downstream O2 sensor on 2012 Yaris | goodmpg | DIY / Maintenance / Service | 4 | 07-22-2021 04:30 AM |
| Air/Fuel sensor and VSV sensor ohms reading. | Misha | DIY / Maintenance / Service | 2 | 02-06-2019 06:32 PM |
| Rear Speed Sensor Install Help? (ABS Sensor) | towerofpower | DIY / Maintenance / Service | 2 | 04-07-2014 07:32 PM |
| The "let's brainstorm how to make a piggyback work" thread | eTiMaGo | Forced Induction Forum | 83 | 08-17-2011 04:54 PM |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 07:38 PM |
