Old 04-07-2014, 06:13 PM   #1
towerofpower
Drives: 2007 Toyota Yaris
Rear Speed Sensor Install Help? (ABS Sensor)
I have a 2007 sedan, auto 1.5L, and the dreaded ABS and brake light are on. I'm attempting to fix the problem myself. I checked the rear left sensor and the connectors were good. Unfortunately, the right rear sensor connector was corroded and broke off :c
I ordered the parts for the rear speed sensor wire, and I looked at the repair manuals. The repair manuals only show how to replace the front speed sensor wires not the rear. For the rear speed sensor, it only shows to to disconnect it from the abs sensor.
Does anyone have any experience in how to replace the rear speed sensor wire or where to find it in the manuals?
Thanks!
towerofpower is offline   Reply With Quote
Old 04-07-2014, 06:21 PM   #2
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Hope u order the harness too u will need it as for sensor it's part of the hub bearing in the rear so u would need to replace hub too .
Old 04-07-2014, 06:32 PM   #3
The rear speed sensor wires go from the sensor up though a floor grommet and into a connecter inside the car. Just follow the wire from the sensor to the floor.
abs light, abs sensor, brake light, speed sensor
Consumer Reports not too pleased with Yaris Befuddled General Yaris / Vitz Discussion 132 02-28-2011 02:57 PM
Yaris Brake Grinding Mike R DIY / Maintenance / Service 4 07-12-2010 10:19 AM
