Old 10-16-2022, 03:48 PM   #1
michael.pxvx
Drives: 2009 3dr 1.5l Auto Base
Unhappy Loud rattle coming from engine/engine area
Hey y’all, I recently picked up a 2009 3dr auto base Yaris. I’ve been having this rattle show up whenever i’m in drive or reverse, only when the car isn’t moving. Tap the gas, it goes away. I’ve picked apart every thread about these rattles, I don’t have ac so it’s nothing to do with that, I checked the shift cable that everyone talked about and it’s not coming from there, it sounds like it’s somewhere in/on the engine, but i can’t pin point it.
I’ll try and attach a video so you can hear the sound, it’s pretty loud and hard to ignore. I’ve resorted to putting the car in neutral at red lights at this point.
I’m hoping for the fastest and cheapest way around this. I’m coming from a 2013 Lincoln mkt which was a panic attack on wheels with 675000 kms, so the goal with this one was less work and stress while i’m in university.
Any help is appreciated!
https://vimeo.com/760836243
Last edited by michael.pxvx; 10-16-2022 at 03:56 PM. Reason: adding video to help diagnose issue
michael.pxvx is offline   Reply With Quote
Old 10-16-2022, 08:13 PM   #2
momoivanoff
Drives: Yaris 2009 Hatchback
The heat shield is loose,it's visible in the video.
momoivanoff is offline   Reply With Quote
Old 10-16-2022, 08:23 PM   #3
michael.pxvx
oh cool, that was easy.
Should I remove it or secure it somehow? Or does it have to be replaced?
Old 10-16-2022, 08:34 PM   #4
momoivanoff
You can remove it and drive without it.If there is no way to hold it with fasteners because of corrosion and you insist on using it you can do like I did,keep it tight with stainless steel zip ties.It's been years since I did and no issues so far.Look up online how to tighten steel zip ties with pliers if you decide to go down that route.
rattles
Please help with Rattle coming from cam cover? c-dub DIY / Maintenance / Service 11 08-07-2011 09:33 PM
2010 US 5 door stock exhaust, big rattle 127.0.0.1 DIY / Maintenance / Service 3 06-20-2010 09:39 AM
strange creak coming from trunk area The LPT DIY / Maintenance / Service 0 05-10-2010 04:06 PM
How to get rid of that horrible rattle from your hatch area. talnlnky DIY / Maintenance / Service 10 11-28-2008 11:57 AM
Weird rattle coming from teh egg. Impresive-G DIY / Maintenance / Service 14 11-10-2008 03:22 AM
