Old 06-18-2010, 10:22 AM   #1
127.0.0.1
2010 US 5 door stock exhaust, big rattle
My 10,000 mile Yaris HB has develped a loud exhaust rattle
when I am sitting still and hit reverse, the RPM's drop a bit and a loud
rattle can be heard, either from the flex coupling on the exhaust or a heat
shield.
it sounds like a spring is loose. it is a metallic rattle that comes and goes
on low rpm. doesn't happen when rpms go up. sometimes happens when
I am moving from park to D and standing still. I hit the e-brake and got
out of the car and it sounds like mid-body, not up near engine...
Anyone else had this ? I am taking it to the dealer for an ordinary oil change
and tire rotate, and was gonna ask them to check out the rattle.
Old 06-18-2010, 11:33 AM   #2
shield.
There was the TSB for 07-09 about the transmission control cable rattling in reverse. That same issue may be there for the 2010s as well.
T-SB-0336-09 Rattle Noise from AT Control Cable in Reverse.pdf
Old 06-18-2010, 11:54 AM   #3
127.0.0.1
Attachment 34527
this ain't that. I got the cable on lockdown with a tiewrap
Old 06-20-2010, 09:39 AM   #4
127.0.0.1
it was a bent heat-shield. odd...wonder how that happened
2010 YARIS 3 door : RATTLE : air vent on the passenger side ... Hershey DIY / Maintenance / Service 7 06-11-2010 05:01 AM
FS: Megan Racing Exhaust n Header. Sabretooth Items for Sale by private party 6 05-17-2009 05:04 PM
does BACK-PRESSURE increase MPG vs straight thru... marcus Fuel Economy Forum 25 05-03-2009 09:23 PM
Exhaust rattle? Cutie Pie #2 DIY / Maintenance / Service 3 11-14-2008 06:46 PM
