Old 10-23-2022, 11:56 PM   #1
fatmanseun
Drives: 2004 echo
brake pad rotor replacement
Good day, I am planning to change the brake pads and rotors myself. To make the job easy, I would like to know how to turn the steering wheel to one side with only one wheel jacked up. I have 1 scissor jack and 4 jack stands. Thanks.
fatmanseun is offline   Reply With Quote
Old 10-24-2022, 01:27 AM   #2
bronsin
bronsin's Avatar
Can you post a picture?
Old 10-24-2022, 12:43 PM   #3
sh0rtlife
if you have 4 jack stands then jack up the front half of the car...turning the wheel while only up on a scisor jack is not advised, nor is it if you have a single jack stand under the car
you can jack up the entire front half of the car off of the transmission front center of the car
Old 10-24-2022, 10:28 PM   #4
fatmanseun
Drives: 2004 echo
Thank you for your suggestion. I cannot find the jack point to lift the front half. I can borrow a floor jack from a friend.
Old 10-25-2022, 12:35 AM   #5
sh0rtlife
look under the front and youll see a flange between the oil pan and the trans oil pan jack there its the spot ive been using for a decade+ now....i use my trailer hitch to do the rear half
brake pad rotor jack
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 08:50 AM
"Thunk" sound after caliper and brake pad replacement Hamster DIY / Maintenance / Service 3 08-22-2020 10:34 PM
Front brake caliper pins DarkSkyGhost DIY / Maintenance / Service 7 06-10-2014 08:05 AM
red hot brake shoes tommo DIY / Maintenance / Service 1 08-31-2011 07:34 PM
SS Brake Line + Brake Pad + Rotor Installed~ AlainMikli Performance Modifications 45 03-20-2010 10:55 PM
